ᐅ How can I stabilize Ikea Pax wardrobes when building them very tall?
Created on: 27 Oct 2024 16:07
NaunoHello everyone,
I am currently planning a very tall setup with several Pax wardrobes stacked on top of each other and want to ensure that the construction is absolutely stable. Specifically, I am looking for ways to permanently stabilize Ikea Pax units, especially when stacked very high, to prevent any tipping risk or unwanted movement.
I have already considered adding extra wall anchors, but the standard wall fixings that come with the Pax units don’t seem sufficient for this height—mainly due to the leverage effect and weight.
What techniques or tools do you use when assembling such tall Pax configurations? Are there any proven tricks or modifications to significantly increase stability?
Thank you in advance for all your replies, including any tips on materials, professional advice for wall attachments, or alternative reinforcement options.
Hey Nauno,
great question, and especially with tall stacked units like Pax, you definitely don’t want to take shortcuts — otherwise, it can quickly become a shaky risk. 😊
I would definitely recommend not only attaching the modules with the supplied wall brackets but also reinforcing them with sturdy metal brackets fixed between the individual cabinet modules. This creates a kind of interlocking effect and greatly increases stability.
It also helps to check the floor and wall beforehand: especially in older buildings, it’s often useful to use anchors placed in the strongest spots (usually concrete or masonry, not just drywall).
This is exactly where my advice applies — better to use more and solid wall hooks than to leave too much free space.
And if you want to be extra safe: hardware stores also offer metal profiles that you can screw behind the furniture to connect the entire construction as one unit. They’re known as “cabinet connectors” or “stability strips” — I can only recommend them.
Hope this helps!
Nauno schrieb:
I have already considered adding extra fixings to the wall, but the standard Pax wall mounts don’t seem sufficient at this height
Hope this helps!
PeoDaniel27 Oct 2024 19:12Hello Nauno,
I would like to briefly add some basics that might help you better assess and improve the stability of your very tall Pax assembly.
The key point with very tall furniture stacks like Pax is always the so-called tipping prevention, since the center of gravity is higher and the leverage acting against the wall fixing increases significantly. Therefore, it is important that the wall attachment
- is distributed as deeply and widely as possible
- is anchored in load-bearing material (such as solid concrete or load-bearing masonry)
- the connection between the individual cabinet units is firm and stable
Additionally, here are a few practical tips:
- You can connect the cabinets internally with wooden battens or metal profiles so they form a mechanical unit. This prevents the modules from moving relative to each other.
- Use adjustable leveling feet under the cabinets to avoid tipping and to compensate for uneven floors.
- Depending on how high the stack is, it is advisable to use so-called "L-brackets" or reinforcements at the upper edge to better transfer the load to the wall.
If you can share how many modules you are stacking or how high the assembly will be, I can provide more specific advice.
That is a very good idea and significantly strengthens the construction.
dijan schrieb:
At the hardware store, there are also metal profiles that you can screw behind the furniture to effectively connect the entire construction as one unit.
Interesting discussion here! Honestly, I find that people often overestimate the risk of Ikea Pax wardrobes tipping over—especially when they are installed correctly.
That said, I wonder: How exactly “very tall” is your setup? Height is often used too quickly as a reason to add extra fixings without considering whether it’s truly necessary.
The fact is: Ikea Pax is designed to be sturdy, and if you follow the assembly instructions carefully—including the wall anchoring, which is really effective—you don’t necessarily need additional hardware. However, if you plan to go beyond 2.5 meters (8 feet 2 inches), then yes, it might make sense, though I remain skeptical whether the extra effort is always justified.
My advice: Instead of overcomplicating the installation, think about the wardrobe layout. It’s better to join several smaller stacks side by side than to build one very tall single tower. This stabilizes the whole structure without having to deal with fiddly adjustments that might cause unintended problems.
So, can you specify exactly how tall and wide your construction is intended to be? That would be crucial to assess whether the standard setup is sufficient.
Nauno schrieb:
I have been considering adding extra wall anchors
Thanks for the feedback so far!
Regarding the exact height: I plan to stack the Pax units so that the wardrobe reaches about 2.9 meters (9.5 feet) tall. This actually consists of three modules, each 236 cm (93 inches) high, placed vertically on top of each other (each with a full front panel and without removing any shelves in between). The width is around 100 cm (39 inches), so it's quite narrow.
I am aware this is not a standard setup, and I do not intend to take any unnecessary building steps. However, precisely because of the height, I am concerned that the Ikea wall brackets alone may not provide enough stability, especially since my wall is drywall with wooden studs behind it.
Now you know. Therefore, I am asking this question very specifically: What practical and safely executable measures would you recommend for such a height to ensure the whole structure is truly stable and durable?
A combination of connectors between the modules, additional wall mounting, and floor leveling seems reasonable to me. Are there, however, any specific differences in suitable screws or fixing materials when dealing with drywall with wooden studs?
I am grateful for any practical advice.
GALEO4 schrieb:
Ich frage mich allerdings: Wie „sehr hoch“ ist dein Aufbau denn genau?
