ᐅ How can I stabilize IKEA Brimnes furniture on an uneven floor?
Created on: 28 Jun 2021 14:37
Pilot
Pilot
28 Jun 2021 14:37
I recently purchased and assembled several IKEA Brimnes furniture pieces, mainly dressers and shelves. Unfortunately, I noticed that my room’s floor is not completely level—there are slight uneven spots causing the furniture to wobble or tilt when weight is applied.
My question is: What methods or special accessories would you recommend to securely stabilize IKEA Brimnes furniture on an uneven floor without damaging the furniture or compromising its stability? Are there, for example, suitable furniture glides, rubber pads, or other solutions that fit well? I am especially interested in practical tips that can be done by myself without too much effort or special tools.
Thanks in advance for your well-informed advice!
Domau0
28 Jun 2021 18:46
Hello Pilot,
your question is very relevant – uneven floors do present a challenge for furniture like the Brimnes series, which is mainly made of particleboard with veneer and therefore relies on stability. To securely stabilize your furniture, several factors need to be considered:
- First, you should assess the exact type of floor unevenness: Are there small dips, larger holes, or a slope? This influences the choice of support solutions.
- A simple and proven solution is height-adjustable furniture glides with rubber coatings. These are attached to the furniture legs and can be individually adjusted so that the furniture rests fully on the floor. IKEA does not always offer such glides, but suitable sets can be found at hardware stores or specialist online retailers.
- For minor unevenness, self-adhesive furniture pads made of rubber or felt can be used under the feet. However, for larger differences, these do not provide sufficient stability.
- Another tip is to use stable wedges made of wood or plastic, placed strategically under the furniture. These should be secured well, possibly with double-sided tape, to prevent slipping.
- If the furniture tips because it could be attached to the wall, you should definitely use the wall fasteners supplied by IKEA; these provide additional safety.
- Finally, the timing of assembly also plays a role: All screws and connectors should be tightened firmly and correctly. A sturdy setup reduces movement despite floor unevenness.
Could you describe in more detail how severe the unevenness is and whether the furniture tipped over or only wobbled? That would help to tailor the recommendations better.
Danabla
29 Jun 2021 09:22
I would like to add to and clarify Domau0’s comments. The stabilization of IKEA Brimnes furniture on uneven floors is most effectively achieved using the following methods and materials:
- Adjustable furniture glides: These are usually made of metal with plastic or rubber pads. They allow precise compensation for differences of a few millimeters and protect the floor.
- Rubber mats or anti-slip pads: These provide grip and prevent slipping on smooth surfaces. They are especially effective on laminate, tile, or hardwood floors.
- Wooden or plastic wedges: These can be cut to fit exactly. It is important that they are firmly fixed to prevent movement. Alternatively, construction wedges (e.g., plastic shims) can be used for fine adjustments.
- Wall fasteners: For Brimnes furniture, IKEA recommends using the included wall brackets to prevent tipping caused by unstable floor contact. These are particularly important if the floor is significantly uneven.
Additionally, during assembly, make sure all screws are tightened and all connections fit properly, as loose components reduce stability.
Generally, solutions that do not require drilling or involve minimal effort should be preferred to avoid damaging the furniture. If in doubt, a combination of the above measures is recommended to prevent tipping, wobbling, and floor damage.
In summary: Adjustable furniture glides are the best choice for Brimnes, due to its mostly rectangular feet, complemented by anti-slip pads and, where possible, wall fasteners.
Perhaps there are more specific questions about your situation?
SUDAN
30 Jun 2021 11:14
Hello Pilot,
I would like to provide you with a practical guide on how to stabilize your IKEA Brimnes furniture on uneven floors. I will focus on simple steps and common mistakes to avoid.
1. Assessing the Unevenness:
- Use a spirit level or simply a filled glass to measure the floor unevenness at the furniture location. Minor unevenness below 5 mm (0.2 inches) is normal, while larger irregularities need to be leveled.
2. Choosing the Right Furniture Glides:
- Since Brimnes furniture usually does not have traditional legs but solid sides, the best option is an adjustable-height glide that can be attached under the furniture base (e.g., the cabinet bottoms).
- Use glides with rubber pads to prevent slipping.
3. Using Wedges:
- For larger height differences in the floor, you can place wooden wedges under the relevant parts of the furniture. These must fit well and be secured. Double-sided tape or rubber adhesive pads can help here.
- Warning: Wedges should never distort or put stress on the furniture body, as this can cause damage.
4. Wall Fixing:
- Brimnes furniture is often tall and prone to tipping. The included wall fasteners must be used to securely prevent tipping.
5. Assembly Check:
- Check all screws for tightness since loose joints increase wobbling.
Finally, an important tip: Avoid temporary solutions like shoved-together cardboard strips or unprofessional fillers, as these neither improve stability nor protect the furniture or floor surface in the long term.
If you want, I can also share the ideal product names and sources for furniture glides that I used for a similar issue.
