ᐅ How can I reinforce Ikea BESTA furniture to safely store heavy items?
Created on: 3 Jul 2023 18:23
baulenox
baulenox
3 Jul 2023 18:23
I am planning to use my Ikea Besta furniture as storage for some quite heavy items, but I’m concerned that the standard joints and materials may not be strong enough to safely support the weight over time.
My specific question is: How can I best stabilize and reinforce Ikea Besta units when using them as shelving for heavy loads? Are there proven methods to increase stability and load capacity? I am thinking of additional fasteners, reinforced back panels, gluing the panels, or other practical tips that also take into account the often modular design of the Besta system.
It would also be important for me to know if there are any limitations regarding the maximum load of individual modules and which specific reinforcements IKEA officially recommends or users find particularly effective.
Many thanks in advance to everyone willing to share their knowledge and experience!
gasidney
3 Jul 2023 20:11
When dealing with heavy loads, I recommend replacing the back panel or reinforcing it with a double layer. Additionally, you can install metal brackets on the inside at the joints to increase stability. Avoid concentrating too much weight on individual shelves.
Surela
4 Jul 2023 07:58
Hello baulenox,
Very good question, especially since BESTA is definitely not primarily designed for industrial use but rather for residential purposes. The stability is mainly limited by the relatively thin particle boards and the simple dowel connections. If you want to use the furniture for heavy loads, I recommend the following step-by-step approach:
- Replace or reinforce the back panel with an additional MDF board (at least 6-8 mm (0.25-0.3 inches) thick), installed from the inside. The back panel is crucial for bracing against lateral bending.
- Instead of the standard wooden dowels, use screw connections or metal brackets. This significantly strengthens the connection between the side panel and the bottom element.
- Use a high-quality wood glue on the joints to minimize twisting or wobbling.
- Metal corner braces aligned with the axes can add considerable tensile strength.
- Distribute heavy loads as evenly as possible and avoid point-loading large weights on individual shelves.
- If possible, add additional crossbars from underneath, for example using metal or wood profiles.
I am still wondering about the weight classes you plan to store? That would help to better tailor the reinforcement dimensions.
Best regards!
labar43
5 Jul 2023 12:47
Surela schrieb:
I’m still wondering about the weight classes you want to store?
I’d like to join in on that! With modules like these, it’s definitely an important issue, but with some DIY skills you can get a lot out of it!
In my experience, the BESTA units can easily handle more weight if you properly reinforce the back panel and add extra brackets. It’s important not just to focus on the appearance but also on the structural integrity. It’s best to reinforce the shelves beforehand, maybe with plywood panels, to prevent sagging.
Keep at it, you’ll manage!
