ᐅ How can I find out which replacement parts I need for Ikea Platsa?
Created on: 9 Feb 2023 08:23
narbrit
Hello everyone, I have an Ikea Platsa system that has been in use for several years. Now I need replacement parts but am not sure how to find out exactly which parts I should order. I’m particularly interested in how to best identify the article numbers or names of the individual components to get the right replacement parts. Does anyone know a reliable method or have helpful tips for accurately determining the needed Platsa replacement parts? For example, is it enough to use the original assembly instructions, or are there other tools or sources that can help with this reliably? I want to avoid ordering parts that don’t fit. Thank you in advance for your help!
kasan
9 Feb 2023 11:15
I believe it's also important to ask why replacement parts for Platsa are needed – are they wear parts, or are the issues caused by installation errors? The selection of replacement parts varies significantly depending on this. For example, if someone just needs a broken hinge, they should check whether it is the current version of that hinge type or an older one, as the manufacturer sometimes changes components without updating the entire model. This makes identification and ordering more difficult. Therefore, providing precise information about the year of manufacture and purchase date is helpful.
narbrit
9 Feb 2023 12:02
Thanks in advance for the tips! The information about the construction year is a helpful hint—I bought the Platsa combination about 5 years ago. Only the drawer slides are now frequently sticking, and I suspect the rollers or rails are worn out or bent. How exactly can I identify such technically smaller but important parts? Especially since the rollers and rails are often not explicitly listed in the regular assembly instructions.
teyosef
9 Feb 2023 12:29
narbrit schrieb:
How exactly can I identify technically smaller but important parts? Especially the rollers and rails are often not explicitly listed in the regular assembly instructions.
That is a very good point that many overlook. For such parts, I recommend the following approach:
- Obtain the complete spare parts list for the Platsa series. Ikea sometimes provides this as a PDF upon request or as an attachment in the assembly instructions.
- Specifically search for the components of the drawer runners, as these are often listed separately.
- Measure the existing parts precisely (width, length, type of roller or rail).
- If the parts themselves do not have a number, comparing them with original parts at an Ikea spare parts center or through phone support can help.
Personally, I have ordered rollers based on self-identification before – to be sure, I always measure at least three dimensions and compare them with Ikea’s specifications.
Charles
9 Feb 2023 13:07
teyosef schrieb:
I personally have ordered the rollers once through self-identification – to be safe, I always measure at least 3 dimensions and compare them with the Ikea specifications.
That is a very good practice. Dimensional accuracy is especially important with moving parts. Otherwise, the replacement part may end up impairing the functionality rather than improving it.
JORDON
9 Feb 2023 14:45
You shouldn’t overcomplicate things! If the rollers are sticking, first check if they just need cleaning or a light oiling. Sometimes the solution is right in front of you. Ordering replacement parts is, of course, the next option, but it’s worth quickly checking if a simple maintenance will do. This way, you save money and resources! 😉
pikin
10 Feb 2023 09:21
JORDON’s comment is valid, but to add to the maintenance advice: For Ikea Platsa, the “movable” spare parts such as rollers and drawer slides are standardized assemblies. If these show above-average wear, it is recommended to replace them through official channels, as repair attempts or homemade replacements can impair functionality.
When identifying spare parts, it is helpful to know the exact serial number. For Platsa, this is usually stamped inside the cabinet frame or found on a sticker. This number is very useful when communicating with Ikea.
