ᐅ How can I find out which replacement parts I need for Ikea Platsa?
Created on: 9 Feb 2023 08:23
narbrit
narbrit
9 Feb 2023 08:23
Hello everyone, I have an Ikea Platsa system that has been in use for several years. Now I need replacement parts but am not sure how to find out exactly which parts I should order. I’m particularly interested in how to best identify the article numbers or names of the individual components to get the right replacement parts. Does anyone know a reliable method or have helpful tips for accurately determining the needed Platsa replacement parts? For example, is it enough to use the original assembly instructions, or are there other tools or sources that can help with this reliably? I want to avoid ordering parts that don’t fit. Thank you in advance for your help!
KINMIN4
9 Feb 2023 08:45
It is best to check the instruction manual or the assembly plan – the parts are usually listed there with numbers. Then you can request the part number directly from Ikea or enter it into their spare parts service.
teyosef
9 Feb 2023 09:12
I can gladly explain in more detail how to find the right replacement parts for Ikea Platsa:
- Step 1: First, you should know the exact Platsa model or combination you own. The best place to find this is on the receipt or in the assembly instructions from Ikea.
- Step 2: Open the assembly guide for your combination – all individual parts are often numbered there.
- Step 3: Once you have the numbers of the broken parts, you can compare them with the replacement part numbers in the Ikea spare parts catalog (usually available online).
- Step 4: For specific parts that are not clearly named, it helps to contact Ikea customer service directly with the model number and a detailed description.
A common mistake is using only the outer name of the furniture. The individual components often have different part numbers which you need to know precisely. That’s why I always recommend having the instructions on hand and not just using the general name.
Charles
9 Feb 2023 09:37
Good point by teyosef. Additionally, I would recommend noting the dimensions of the defective parts and possibly using photos of the assembly – even if no images are uploaded, this approach helps a lot during phone calls with customer service. It greatly facilitates communication and minimizes misunderstandings.
KINMIN4
9 Feb 2023 10:05
If you no longer have the manual, you can often search for the model on the Ikea website, where replacement parts are sometimes listed. This is a quick and easy way to find them.
pikin
9 Feb 2023 10:42
A more precise approach, in my view, is as follows:
- Naming the piece of furniture, e.g., "Platsa cabinet combination 100cm x 100cm (40 inches x 40 inches)"
- Detailed identification of the spare part (hinge, drawer slide, connector fitting)
- Using the official Ikea spare parts search to verify the exact name and part number
It is important not to rely solely on the visual description but to refer to official documentation or a parts list.
Otherwise, there is a risk of ordering parts that look similar within the series but do not match exactly in function or dimensions.
