ᐅ How do I securely install Ikea PAX wardrobes on wooden or tiled floors?
Created on: 27 Sep 2023 08:37
Clair
Clair
27 Sep 2023 08:37
I am currently planning to assemble an Ikea Pax wardrobe at home and want to be extra careful, especially regarding the attachment to different types of flooring. Specifically, I am concerned about safe installation on wooden or tiled floors.
My question is: What special precautions should be taken when fixing the Pax wardrobe frame to wooden or tiled floors to ensure stability and safety?
Are there recommended types of anchors, additional pads between the feet and the floor, or specific assembly steps that help prevent wobbling or damage to the floor? I have also read that Ikea sometimes includes wall fasteners, but I would like to understand the exact procedure, especially when the floor consists of different materials.
Looking forward to your experiences and advice!
Dilen
27 Sep 2023 14:52
Hello Clair,
Your question is very well formulated and important, as the installation safety of Ikea PAX wardrobes is often underestimated, especially on different types of flooring. I will address both floor types step by step:
- Wood flooring:
In general, wood is a relatively flexible and soft surface. To prevent the PAX wardrobe from sliding or leaving pressure marks, it is worth combining anti-slip pads with sturdy mounting elements. I recommend placing felt gliders or special furniture pads under the wardrobe feet. These protect the floor while still providing some grip.
Wall mounting is very important with PAX to prevent tipping – ideally using screws into load-bearing wall areas (for example, into wall studs or with appropriate anchors for concrete or brick walls). Be sure to choose anchors and screws suitable for your wall type.
- Tile flooring:
On tiles, slip resistance is lower and the risk of wobbling or damage is higher. Here, I would add rubber-like anti-slip mats designed specifically for tiles in addition to furniture pads. This reduces wobbling.
The same applies to wall mounting, but when drilling into tiled walls, you need to be more careful. It’s best to use a hammer drill with suitable masonry drill bits and appropriate expansion anchors or cavity wall anchors, depending on the location.
One more tip: After installation, check with a spirit level whether the wardrobe is standing straight and adjust the feet of the PAX wardrobes if necessary. Slightly height-adjustable leveling feet are a plus.
Regarding fixing the wardrobe to the floor itself: Ikea generally does not recommend floor anchoring, as the main focus is on wall attachment. However, if you want to stabilize the wardrobe in a corner or open space without a wall, it might make sense to consider floor anchoring with suitable anchors – but only if the floor allows it.
I would also like to know what type of wall you have and which PAX models you plan to install – this way, the installation steps can be tailored more precisely.
Best regards!
Paunon
27 Sep 2023 18:46
Hello Clair,
For wooden or tile flooring, please follow these guidelines:
- Always use the supplied wall brackets and securely fix them to the wall.
- Place felt pads or rubber pads under the cabinet feet to prevent floor damage.
- For tile floors, ensure the use of non-slip underlays.
- Adjust the feet to be height-adjustable so the cabinet stands securely.
This ensures stability and protects the floor.
anken
28 Sep 2023 09:13
Dilen schrieb:
Wall anchoring is very important for PAX to prevent tipping – preferably using screws into stable wall areas (for example, into wall studs or with appropriate anchors for concrete/brick walls).
I want to emphasize this here. Even if the wardrobe stands on a solid floor, wall mounting is the crucial safety feature, especially for tall units like the PAX models.
Also: For tiled floors, it’s best to use high-quality anchors and drill bits specifically designed for tiles to avoid damage. If the wall composition is uncertain, professional advice or the use of chemical anchors is recommended.
To protect the floor, rubber pads are better than felt because they provide more grip and distribute the load more evenly. Especially in bathrooms or kitchens, keep in mind that moisture can damage felt pads over time.
One final tip: Before installation, check all levels with a spirit level and, if necessary, adjust using leveling feet. Since PAX is often modular, you can align individual elements before securing everything permanently.
I hope this helps.
