ᐅ How can I securely mount Ikea Metod wall cabinets on drywall?
Created on: 19 Oct 2024 09:27
fomare
fomare
19 Oct 2024 09:27
I am currently installing Ikea Metod wall cabinets in my kitchen. However, the wall where the cabinets will be mounted is made of drywall (gypsum board). My specific question is: How can I securely and permanently attach the Metod wall cabinets to a drywall surface so that the weight of fully loaded cabinets is supported and the risk of anchors pulling out or even falling is avoided?
I understand that drywall is not as load-bearing as solid walls, but which fastening methods, anchors, or reinforcements are specifically recommended for mounting Metod wall cabinets?
It would also be helpful if someone could share their experience on whether and how the Ikea mounting frame or additional mounting battens can assist when working with drywall walls.
Thanks in advance for your tips!
Kinbu
19 Oct 2024 10:36
Hello fomare,
First of all, a big compliment for your very clear and detailed question – this is always very helpful for providing targeted answers.
Regarding your question about securely mounting the Ikea Metod wall cabinets on drywall: In principle, gypsum boards alone are not suitable for supporting heavily loaded furniture, as they can tear out quickly under high load. It is therefore important to attach the wall cabinet to the underlying load-bearing structure, meaning the wooden or metal studs behind the drywall.
I recommend the following approach:
- Use a stud finder or a magnet to precisely locate the mounting studs behind the drywall.
- Attach the Ikea Metod wall cabinets using the supplied mounting rail at the points where studs are located.
- Be sure to use sufficiently long screws for mounting, which penetrate deep enough into the studs. Ideally, 60–80 mm (2.4–3.1 inches) long wood screws like Spax screws are suitable.
- If there is no stud at the right spot, I do not recommend using simple anchors alone. Instead, consider alternative solutions such as mounting an additional reinforcement board (a wooden plank or OSB panel) screwed to the wall to hang the cabinet on.
Regarding the Ikea mounting frame: It is actually intended for wall mounting and provides somewhat more stable support, but it does not replace a load-bearing wall. Here too, it needs to be screwed into the studs.
If you can install load distribution plates behind the drywall – which is sometimes possible during renovations – this will increase the wall’s load capacity.
Basically:
- Screws must go into load-bearing studs!
- Do not rely on anchors alone in drywall for full wall cabinets!
- Mounting frames or reinforcements can help but do not replace load-bearing beams.
I’m happy to provide tips on the right screw types and mounting materials if needed. Good luck!
Paunon
19 Oct 2024 12:04
If the cabinets are to be mounted on drywall, be sure to screw them directly into the wall studs.
If this is not possible, screw wooden battens to the wall first and attach the cabinets to them.
Using anchors alone is not secure enough for Metod wall cabinets.
Domau0
20 Oct 2024 14:18
Hello fomare,
I would like to go into more detail on the technical aspects of mounting Ikea Metod wall cabinets on drywall, as this topic is often underestimated, and especially the distribution of the load is crucial.
First of all: A fully loaded Metod wall cabinet can easily weigh around 20-30 kg (44-66 lbs) or more, which puts considerable stress on the wall. Drywall panels are not designed to carry such loads; they can only support the weight of lightweight decorations.
Steps for a safe installation:
- Locate and mark the wall studs: Make sure to precisely find every single metal or wooden stud behind the drywall. Stud finders and metal detectors are helpful here, as the panels are at least 12.5 mm (0.5 inches) thick.
- Multi-point fastening: To avoid load concentration, attach the cabinets using as many screws as possible into the studs, ideally at least two screws per cabinet mounting point, spaced vertically.
- Screw selection: Use self-drilling wood screws or equivalent screws at least 70 mm (2.75 inches) long to securely engage the studs. For metal studs, specific metal drill bits and appropriate screws must be used.
- Wall reinforcement: If the studs are very irregularly spaced (e.g., farther apart than the cabinet width), you can reinforce the wall by installing a sturdy plywood panel or a notched support batten. This is screwed directly to the studs, and the cabinets are then attached to this wider structure.
- Mounting frame: Ikea offers frames for Metod cabinets that help distribute the load more evenly. It is important that this frame is also properly fastened to the studs. It spreads the force over a larger area and prevents point loads on the drywall.
You should also consider the weight of the cabinet openings (door fronts and drawers), as opening them creates additional leverage and stress on the fastenings.
In summary:
- No secure fastening without studs
- Reinforce with wooden battens if stud spacing is unfavorable
- Use different screws for metal studs
- Mounting frames are useful but only as a supplement
I hope this helps. Can you already locate the studs at your place? What are the distances? Then we can be more specific.
likuken
20 Oct 2024 20:03
Domau0 schrieb:
I hope this helps you. Can you already locate the studs on your wall? What are the distances between them? Then we can get more specific.
In a typical “Ikea-type installation on drywall” discussion, I think it’s important to be honest: Anyone who thinks to simply hang it using anchors on drywall hasn’t really understood the basic principle of load-bearing structures.
Many claim here that mounting strips and frames help – that can sometimes work, but in the end it’s always a compromise and rarely truly professional. If the project is meant to last seriously long, you should consider a proper substructure or even reinforce the drywall at that spot with solid wood panels (e.g., plywood).
Just because Ikea provides instructions for wall mounting with anchors doesn’t mean it’s a free pass to do so – drywall alone is not a load-bearing material suitable for this type of heavy furniture.
So, if you want a simple and safe solution, either make sure from the start that the cabinets hang on load-bearing studs or don’t hesitate to invest the effort in installing a reinforcing panel behind the drywall. Everything else is a makeshift solution that may hold up in the short term but poses a safety risk.
Just my opinion – but I think it’s important that these discussions don’t stay superficial and that the risks are made clear.
