ᐅ How do I securely mount Ikea Metod wall cabinets on different types of walls?
Created on: 24 Sep 2024 08:37
Hauirina
I am currently planning to install Ikea Metod wall cabinets in my apartment and have some uncertainties, especially regarding the appropriate fastening materials and methods for different wall types. My main question is: How can I securely mount Ikea Metod wall cabinets on various wall types such as concrete, brick, drywall, or wood stud construction? I am particularly interested in recommendations concerning the suitable types of anchors, screw lengths, and any special considerations for load distribution.
I want to avoid damage to the walls caused by improper fastening or the cabinets later becoming unstable or even falling. Do you have detailed tips, preferably step-by-step instructions or advice on common mistakes with certain wall types? Thanks in advance for your support!
Dilen schrieb:
Drywall anchors: Common hollow wall anchors work by expanding inside the cavity, but they have limitations. Distributing the load over a wooden batten (at least a 40x60 mm (1.6x2.4 inch) profile) is not optional here, but mandatory when cabinets are loaded with more than 10 kg (22 lbs).Interesting argument, but in my experience, that is often overly cautious. Many people manage to install Metod cabinets on drywall using only hollow wall anchors, especially when they are lightly loaded.
My provocative claim is: Most manufacturers tend to play it safe and recommend a mounting batten – but for many applications, this is oversized and leads to unnecessary extra effort and costs.
So why not first calculate the actual weight of the intended load and then decide? Some people overestimate the load, particularly with dishes – which are often lighter than expected.
Only 10 kg (22 lbs) as a limit doesn’t always seem realistic to me.
likuken schrieb:
So why not calculate the actual weight of the planned load beforehand and then decide?Exactly, that balances the effort. Still, it’s better to be safe – a falling wall cabinet on drywall can cause more damage than you might expect.
If you’re really unsure, install a batten or have someone with experience check it.
