ᐅ How do I securely mount Ikea Metod wall cabinets on different types of walls?
Created on: 24 Sep 2024 08:37
HauirinaHello everyone,
I am currently planning to install Ikea Metod wall cabinets in my apartment and have some uncertainties, especially regarding the appropriate fastening materials and methods for different wall types. My main question is: How can I securely mount Ikea Metod wall cabinets on various wall types such as concrete, brick, drywall, or wood stud construction? I am particularly interested in recommendations concerning the suitable types of anchors, screw lengths, and any special considerations for load distribution.
I want to avoid damage to the walls caused by improper fastening or the cabinets later becoming unstable or even falling. Do you have detailed tips, preferably step-by-step instructions or advice on common mistakes with certain wall types? Thanks in advance for your support!
Hello Hauirina,
your question is very relevant and often underestimated, especially with IKEA Metod wall cabinets, whose weight can be considerable depending on the load. Here is a structured guide that should help you:
- Concrete wall: Use heavy-duty metal anchors (e.g., expansion anchors or sleeve anchors). The screw length should be anchored at least 50 mm (2 inches) into the wall. Make sure to place the anchors at least 10 cm (4 inches) away from edges to avoid cracking.
- Solid brick wall: Nylon anchors with a suitable screw are sufficient if they are inserted deeply enough (at least 60 mm (2.5 inches)). If the bricks are hollow, a hollow wall anchor or special toggle bolts are recommended.
- Drywall (plasterboard): Special care is needed here. Use cavity anchors or, even better, install an additional wooden batten or metal profile as a support structure to which you attach the cabinets. Otherwise, the cabinets are too heavy for the thin wallboard alone.
- Wooden support structure: Screws into the studs are the most secure option. It is best to locate the exact positions of the studs beforehand using a stud finder.
Common mistakes include choosing the wrong size anchors, sloppy drilling, and attaching the cabinets only at the edges. Always check the maximum load capacity of the anchors you use.
In summary: identify the wall type, choose the appropriate anchors, reinforce drywall if necessary, and always make sure the load is distributed when mounting. If you like, I can provide you with a detailed installation checklist.
I am adding an important point to Jensson’s comments:
Load distribution is crucial for Ikea Metod cabinets, as they are often loaded with water, dishes, or other heavy items. Therefore, in addition to choosing the right wall anchors, I recommend installing a mounting strip or mounting board behind the cabinets if the wall does not have a consistently solid structure.
This is especially true for drywall (plasterboard) walls, but also for uneven brick walls, where individual anchor points may limit load capacity.
Also, always use a suitable mounting bracket or the included Ikea fastening hardware, as it is specifically designed for the construction and often distributes loads more efficiently than simple screws directly into the cabinet back panel.
Any potential vibrations or stresses from opening and closing should also be considered – this means properly preparing the drill holes and, if necessary, checking the screws again after installation.
For safety, here are some technical specifications that are crucial when choosing anchors:
- For concrete walls: Use expansion anchors with a diameter of at least 8 mm (0.3 inches); the load capacity is usually between 80–100 kg (175–220 lbs) per anchor.
- For solid brick walls: Use 8 mm (0.3 inches) nylon anchors with screws 60–70 mm (2.4–2.8 inches) long, considering a load capacity of about 40–50 kg (88–110 lbs) per anchor.
- For drywall: Use metal cavity anchors that can support approximately 20 kg (44 lbs). For heavier cabinets, reinforcement with a battens installed behind the drywall is essential for secure fastening.
- Screws: Use galvanized or stainless steel screws with a diameter of at least 4.5 mm (0.18 inches) to ensure long-term stability.
Another rule of thumb is to use at least two anchors per side of the cabinet, preferably three, to achieve even load distribution. Ikea’s assembly instructions sometimes only specify the minimum requirements, which often is not sufficient in older buildings.
I would like to add a more detailed technical background, especially regarding wall construction and the associated load assumptions:
- Concrete: The tensile and shear strength of a heavy-duty anchor in concrete is high, but it is crucial that the drill holes are made precisely and cleanly. For cracked or old concrete, pre-drilling is essential, and it may be necessary to remove any joints or seams.
- Brick: Classic solid bricks have high compressive strength; however, anchor points in old masonry are often porous. It is advisable to gently tap the wall with a steel nail before installation to test the strength.
- Drywall: Common hollow wall anchors use expansion mechanisms inside the cavity but have limited load capacity. Distributing the load over a wooden batten (at least 40 x 60 mm (1.6 x 2.4 inches) profile) is not optional but mandatory when cabinets are loaded with more than 10 kg (22 lbs).
- Timber substructures: Screws hold best along the grain of the wood. When mounting, pre-drilling is necessary to avoid cracks or splitting.
Important: Before fastening, check with a suitable measuring device for pipes or cables in the wall. Especially in older buildings, these can be hidden near the intended screw points.
I also recommend using a horizontal mounting rail when installing several cabinets side by side so that the load is supported at multiple points and the cabinets do not warp.
