ᐅ How can I securely mount IKEA Metod cabinets on different types of walls?
Created on: 17 Mar 2024 18:02
pupa30
I am planning to install some IKEA Metod kitchen cabinets on my walls. I have encountered different wall types: for example, solid brick, drywall partitions, and partly concrete walls. My specific question is: how can I securely and permanently fix IKEA Metod cabinets to these various wall types?
What fastening materials and techniques are best suited to ensure a safe installation, so that the cabinets do not fall down after some time or damage the wall?
I look forward to helpful tips, especially regarding recommended anchors, screws, and practical mounting systems for each type of wall. Thanks in advance!
KNUTGI
18 Mar 2024 11:33
Ah, the joy of kitchens! 😄
A quick reminder: Metod cabinet walls can get really heavy once pots and pans are inside – so always plan generously for the load-bearing capacity.
My tip for everyone: For drywall, it’s better to install a few strategically placed wooden battens behind the wall and screw into those – this provides extra security and feels more solid.
And hey, if the concrete is a bit stubborn when drilling, use a hammer drill instead of just a cordless screwdriver – it makes the job much easier. 😉
pikin
19 Mar 2024 06:12
Summary for the secure mounting of IKEA Metod cabinets:
- Solid brick: at least 8mm heavy-duty anchors, screws matching the anchor size, length minimum 60–80mm (2.4–3.1 inches)
- Concrete ceilings/walls: metal screw anchors or injection anchors (chemical fastening), drill hole thoroughly cleaned of dust
- Drywall: direct mounting only on stud profiles, hollow wall anchors only for light loads; for heavy loads use a mounting plate or wall reinforcement
It is important to evenly distribute the load over at least two fixation points. Hanging without additional reinforcement on drywall can be risky.
Jensson
19 Mar 2024 09:45
To make this practical, here is a brief step-by-step guide for the most common wall types:
1. Check the wall: Identify the material (solid brick, concrete, gypsum board) and check for any studs behind the drywall.
2. Drill hole: For solid brick use 8mm (5/16 inch) anchors, observe the required depth; for concrete use 10mm (3/8 inch) or larger depending on the anchor; for drywall, drill only into studs.
3. Insert anchors: properly and cleanly; for chemical anchors, clean the hole thoroughly beforehand.
4. Attach the cabinet: use appropriate screws to fasten it to the designated hooks or drill holes of the Metod system.
5. Inspection: align the cabinet and test extensively to ensure it is secure and stable.
Common mistakes I often see: drilling in wrong wall locations, improper choice of anchors, lack of load distribution.
tra_nina
20 Mar 2024 12:07
pupa30 schrieb:
How can I securely and permanently fix IKEA Metod cabinets to these different types of walls?
Finally, I would like to point out that you should always pay attention to the load capacity specifications provided by the manufacturer for the mounting brackets and anchors.
Even with seemingly “stable” walls, cracks can develop around the anchors if the load is too concentrated.
Therefore, for larger cabinet combinations or particularly heavy cabinets, it is advisable to use additional elements such as stronger mounting plates or to distribute the load across multiple fastening points.
It is also good practice to regularly check the cabinets for secure attachment, especially during the first few months after installation.
