Mingokhan28 Feb 2024 08:11Hello everyone, I am planning to install several IKEA Billy bookcases on drywall in my apartment. I am wondering how to secure these shelves as safely and stably as possible without damaging the wall or having the shelves fall down. My main concern is the right materials and techniques—specifically, which types of wall anchors are suitable, how many fixing points should be used, and if there are any special tips for load capacity on drywall. Any advice on mounting height or positioning of the fixings would also be helpful. Thanks in advance for your expert tips!
For securely mounting Billy shelves on drywall, I recommend using metal cavity anchors, such as toggle bolts or snap toggles, which provide higher load capacity than plastic anchors. It is important to ideally screw the anchors into the wall studs, as these can bear the load much better. The number of fastening points depends on the shelf size and expected load; there should be at least three to four per shelf.
Note: The mounting height does not affect load capacity, but the shelf should be positioned as close to the wall edge as possible to minimize rocking.
I think the importance of wall quality is often underestimated. Using only basic toggle bolts quickly limits the load capacity, especially if the Billy shelf is frequently loaded.
A more detailed distinction according to shelf size and weight is missing here.
My tip: If possible, invest in an additional wooden batten as a mounting support, which you attach horizontally to the wall – this distributes the load better and allows you to install more fixing points, even on weaker drywall areas. Exploiting weak spots is too risky otherwise.
Dopoki schrieb:
three to four per shelf should be the minimum.
