ᐅ How can I securely install BILLY shelves on uneven floors?
Created on: 20 Sep 2024 08:47
kautommi49
kautommi49
20 Sep 2024 08:47
I’m planning to place a BILLY shelving unit from IKEA in my study. However, the floor there is not completely level—there is a noticeable uneven spot that makes the shelf quite unstable. My question is: How can I securely install BILLY shelves on uneven floors to avoid stability issues and ensure the unit remains sturdy over time? Are there any specific installation tips, tools, or materials that work particularly well to address this challenge? I’m not looking to just prop it up with some pieces of wood but want to find a professional solution that is also visually appealing. Thanks in advance for your advice!
Nabla64
20 Sep 2024 09:33
Hello kautommi49,
Your question is very practical and important for ensuring long-term stability. Here is how I would approach it – with a simple step-by-step guide:
1. Identify unevenness: First, use a spirit level to measure the spots where the floor is uneven. You can also use small wooden strips or a long board to pinpoint the variations more precisely.
2. Adjust the base: Special furniture gliders or felt pads with leveling functions work best. If the unevenness is significant (about 5 mm (0.2 inches) or more), I recommend installing adjustable furniture feet under the shelf. These are available at hardware stores or online and allow precise height adjustment.
3. Check stability: Place the BILLY shelf in its intended position and adjust the feet so the shelf stands securely without wobbling.
4. Attach to the wall: It is also crucial to anchor the shelf to the wall, as BILLY shelves are often quite tall and can tip over. Use the supplied brackets and wall plugs to fix the shelf safely.
5. Final touches: If desired, you can add decorative skirting boards or baseboards to improve appearance and cover any gaps.
Common mistakes include placing the shelf on an uneven floor without adjustment or neglecting to secure it to the wall. In case of severe floor issues, it might even be advisable to level the floor itself, if possible.
I hope this helps you. If you provide more details about your specific floor, I can give you more precise recommendations.
Filippo
20 Sep 2024 12:18
Nabla64 schrieb:
If the unevenness is too large (from around 5 mm (0.2 inches) and above), I recommend installing adjustable furniture feet under the shelf.
I completely agree. To ensure maximum safety during installation on uneven floors, I recommend the following in detail:
First, measure the actual unevenness using a digital inclinometer or an electronic spirit level. While most traditional spirit levels are helpful, more precise devices provide information about angle deviations that can cause wobbling over small distances.
When choosing adjustable furniture glides, make sure they are sturdy and can be firmly attached to the shelf. There are versions with metal threads that allow for precise adjustment. Installation involves removing the shelf’s original feet and replacing them with the adjustable ones—this way, the height can be corrected to the millimeter.
Additionally, I recommend securing the shelf to the wall at as many points as possible, preferably using solid wall plugs in solid masonry walls. For drywall or similar walls, special anchors are needed. This prevents the risk of tipping.
A small tip: if your floor is severely uneven, place a rubber or cork pad between the shelf leg and the floor to absorb vibrations and reduce wobbling.
One more question: How tall is the shelf and what is its width? This helps to assess the tipping risk.
kautommi49
21 Sep 2024 07:12
The shelf is 202 cm (79 inches) tall and 80 cm (31.5 inches) wide. So it is relatively tall and not very narrow. The floor is uneven by about 7 mm (0.3 inches) at the lowest point. The wall is plastered and made of solid brick.
Nabla64 schrieb:
Wall mounting is crucial to prevent tipping.
I know that, I would definitely secure it to the wall using spacers.
Filippo schrieb:
I recommend rubber or cork pads to dampen vibrations.
That sounds good. Do you have any advice on where I can order those or how thick the pads should ideally be? The uneven spot is directly under one of the feet, so the pad would need to compensate for the 7 mm (0.3 inches) difference as well.
Thanks in advance for the helpful suggestions, I really want to make sure this is done stable and neatly.
juMira46
21 Sep 2024 10:26
kautommi49 schrieb:
The shelf has a height of 202 cm (79.5 inches) and a width of 80 cm (31.5 inches).
You’re definitely addressing a shelf like that with a lot of responsibility – stability is truly the most important factor! 🙂
Regarding the 7 mm (0.28 inch) uneven spot: If you’re looking for something flexible yet load-bearing, I recommend rubber-like pads – preferably with a thickness of 5 to 10 mm (0.2 to 0.4 inch). You can find these not only in hardware stores but also in online furniture accessory shops or even at IKEA (they often have furniture gliders with rubber profiles).
Alternatively, you could create a small “cushion” yourself by stacking several thin rubber pads – that way you can adjust and align it precisely as needed.
Here’s my secret tip: Sometimes it’s worth combining height-adjustable furniture feet with those pads so you get twice the precision for a perfect fit.
Warning: Rubber pads can compress slightly under load, so it’s best to choose a slightly firmer material; otherwise, you might lose the adjustment after a few months.
One more tip: When doing the final assembly, be sure to check all axes multiple times with a long spirit level—that way, you’re really on the safe side.
Good luck! And if the shelf ever wobbles, you can always fine-tune it later with just small adjustments 😉
