ᐅ How can I securely fasten BILLY shelves to prevent slipping?
Created on: 20 Jun 2021 08:17
Effendi9
Effendi9
20 Jun 2021 08:17
Hello everyone, I have a specific concern about preventing the Billy shelves from slipping. In my current setup, the shelves sometimes shift slightly under load, especially when I place heavier items like books or binders. I am looking for a secure, ideally simple and reversible method to fix the shelves firmly in the Billy units. Are there any proven techniques or additional fasteners you would recommend to reliably prevent slipping? Ideally, I would prefer a solution that does not leave visible marks or damage on the shelves and can be implemented with commonly available tools or materials. Thank you in advance!
Surela
20 Jun 2021 09:03
Hello Effendi9,
regarding your question about securely fixing BILLY shelves, I would like to share some practical methods. In principle, the shelves in BILLY systems rest on small support brackets and usually shift very little due to gravity. However, continuous load and slight changes in load naturally cause some movement.
A simple, reversible method is to use small self-adhesive felt or rubber pads, which are attached under the shelves at the support points. These increase friction and reduce slipping.
If you want a more stable fix, you can use shelf supports or special brackets that are screwed to the side panel of the shelf. These provide firm hold but can also be removed later.
Another option is to wedge thin rubber or silicone strips between the shelf and side panel. This creates a kind of spring effect, ensuring a secure position.
A quick question: Have you already made any holes or used screws, or would you prefer to keep the shelf completely unchanged? Best regards!
GU-LAU60
20 Jun 2021 09:47
Effendi9, a simple solution is to attach the shelves to the inside of the side walls using metal shelf brackets. Alternatively, self-adhesive rubber pads or anti-slip mats that you can cut to size also help. This way, the shelves hardly move.
Joshbe
20 Jun 2021 10:25
Effendi9,
To secure BILLY shelves permanently and prevent slipping, the choice of method largely depends on the intended use and the load they will bear. If you prefer no visible alterations or drilling, I recommend using high-quality anti-slip felt pads or narrow silicone strips along the shelf supports. These effectively increase friction without leaving visible marks.
However, if the shelf will hold heavier loads, small metal brackets fixed with screws to the side panels are the most robust method and ensure stable positioning of the shelves. Any holes can be easily filled later with paintable filler or wood putty.
It is also important to check the thickness of the shelves. Standard BILLY shelf supports are designed for 16 mm (5/8 inch) thick shelves. Thinner boards may have problematic play, so reinforcements such as additional spacers on the side panels might be advisable.
Summary:
- Felt/silicone pads for light fixing without marks
- Metal brackets for heavier loads
- Check positioning of support brackets
I hope this helps you further.
klo40
21 Jun 2021 07:14
Effendi9 schrieb:
I am looking for a secure, simple, and preferably reversible method to fix the shelves firmly in the BILLY units.
I completely understand. Here is a short guide on how I secured my Billy shelves:
1. First, it is important that the shelves and support brackets are clean and free of dust or grease. Wiping them with isopropanol helps.
2. I applied thin, self-adhesive anti-slip pads at the points where the shelves rest. These pads are specially designed for glass or wood and provide good grip.
3. For extra stability, I used small corner brackets fixed with wood glue and screws. Place the screws as close as possible to the support brackets to avoid stress on the shelf structure.
4. The brackets can be easily removed if needed.
Note: The original shelf supports are only stable up to a certain weight. If you plan to store heavy items, it is advisable to reinforce the shelves with additional cross braces or stiffeners.
Summary:
- Anti-slip pads under the shelves
- small screw-in corner brackets for more support
- always check how much weight the shelf will carry
If in doubt, you can also try double-sided mounting tape, but this is less reversible. Good luck!
Surela
21 Jun 2021 08:27
Joshbe schrieb:
Felt/silicone pads for light fixing without marks – metal brackets for higher loads
I want to emphasize this and add a bit more: If the shelves are actually removed frequently, I would prefer felt gliders and replace them occasionally. Metal brackets are very sturdy, but especially with multiple adjustments, they can leave marks and damage the wood.
klo40 schrieb:
thin, self-adhesive anti-slip pads stuck where the shelves rest
This is usually the best first solution. Self-adhesive silicone pads are even grippier than felt. But please make sure the surface is well cleaned and free of grease, otherwise the pads won’t hold permanently.
I would also like to mention a method proven in carpentry: groove strips with rubber inserts, glued to the sides of the shelf unit, into which the shelves are then recessed. This requires more effort but is extremely secure against slipping.
How often do you change your shelf setup, Effendi9? Are you looking for a very flexible solution?
