ᐅ How can I securely fix Malm furniture to a wooden floor?
Created on: 4 Jun 2020 18:23
gulau
gulau
4 Jun 2020 18:23
Hello everyone, I have a specific question: I want to securely and stably fasten my IKEA Malm furniture to a wooden floor. The main goal is to prevent the furniture from sliding, tipping over, or generally being unstable. I have read that it’s recommended to fix them to the wall, but in my case that’s not an option because the furniture is placed in the middle of the room. Are there good methods or special materials to securely anchor Malm wardrobes or dressers to wooden floors? It’s also important to me that the wooden floor is not damaged and that the solution is as reversible as possible. I’m looking forward to any tips or experiences you can share!
Donar34
4 Jun 2020 19:17
Your concern is understandable and requires a stable yet gentle solution. The most common method to stabilize Malm furniture on wooden floors without wall mounting is to use non-slip adhesive pads or rubber feet under the furniture legs. These effectively prevent slipping on smooth parquet or plank floors and can be removed without leaving any residue.
Alternatively, special furniture floor protectors with adhesive properties can be used, which also protect the floor. It is important to ensure a large surface area of contact to avoid pressure marks.
If more stability than just slip resistance is desired, I recommend using small brackets or metal plates that can be screwed under the furniture and combined with non-slip mats. However, the underlying wooden floor construction should not be damaged, which may exclude this option for rental apartments.
In summary: non-slip rubber pads or furniture gliders with adhesive function are the most practical and floor-friendly solutions when wall mounting is not possible.
danial60
5 Jun 2020 07:42
Donar34 schrieb:
Non-slip rubber pads or adhesive furniture glides are the most practical and floor-friendly solutions
That’s a good starting point. Additionally, I would like to address the issue in more detail and provide practical tips:
1. Ensuring flatness: Malm furniture can wobble on wooden floors if either the floor or the furniture is uneven. Small adjustable furniture feet can significantly improve stability.
2. Anti-slip materials: Besides common rubber pads, there are also products like anti-slip mats or relatively thin foam rubber sheets that can be placed under the furniture. These increase friction and dampen vibrations.
3. Securing without wall attachment: If extreme stability is required and the floor allows it, flat metal brackets can be attached to the back of the furniture and connected to special floor anchors recessed into the wood. However, this is invasive and needs careful planning.
4. Caution with lacquered or sensitive wooden floors: Directly sticking adhesive pads can sometimes cause discoloration. Test the material on an inconspicuous spot before use.
In your case, where wall mounting is not possible, I consider the combination of adjustable feet and high-quality non-slip pads the best compromise between stability, protection, and reversibility.
pilous
5 Jun 2020 10:35
gulau schrieb:
The attachment to the wooden floor should be damage-free and reversible
Here is my critical question: How severe is the instability issue exactly? Do the furniture pieces slide away with a light touch, or do they tip over when, for example, a drawer is opened?
This determines how much effort is justified. If the Malm wardrobe only slides slightly, non-slip rubber pads under the feet are perfectly sufficient. However, for tipping resistance, more and deeper mechanical fastenings are needed, which will compromise the floor’s integrity.
danial60 schrieb:
attach flat metal brackets to the back and connect them with floor anchors
I consider that overengineered, especially without wall fastenings. Also, keep in mind that wooden floors often do not provide a solid substrate for such anchors, and trial drilling beforehand is absolutely necessary.
I recommend first conducting a more precise assessment: How strong are the forces acting on the furniture? How sensitive is the floor really? And maybe try moving the furniture slightly without any aids to get a better sense.
rebufar
6 Jun 2020 00:13
Not to contradict, but to be honest: Malm furniture is actually poorly designed for floor-only stabilization. If you don't secure it to the wall, you are knowingly risking that it will tip over or slide.
Instead of constantly looking for new "gentle" tricks, one should really consider whether the piece of furniture is the right choice for the intended location.
And if wall fastening is truly not possible, I see it as a clear design challenge that more robust measures are then necessary. These can certainly include heavy-duty, difficult-to-conceal anchors.
Anything else seems like trying to fix a defect with a band-aid.
