Hello everyone, I recently bought a Malm sideboard from IKEA and noticed that my floor is quite uneven. Unfortunately, this makes the furniture unstable, which concerns me regarding safety.
My question is: How can I securely fix MALM furniture on an uneven floor? Are there specific tips or tricks to ensure a safe and tip-resistant setup despite floor irregularities? I am especially interested in solutions that do not require major modifications to the furniture or the floor, as I am renting.
I look forward to your advice and experiences. Thank you in advance!
KINMIN4 schrieb:
For larger unevenness, plastic shims helpThat is correct; plastic shims or adjustable furniture feet provide a good base. However, I would recommend ensuring additional stability, especially for MALM furniture, by securing it to the wall.
MALM dressers are relatively wide and can tip over on uneven floors, particularly if they are only placed loosely. IKEA usually provides small brackets and screws that allow you to fix the furniture to the wall without altering the floor.
It is advisable first to even out the unevenness using filler or small wooden shims and then secure the furniture to the wall with the included brackets. This way, tipping is prevented permanently and safely.
Also, make sure the brackets are fixed to solid masonry and not just drywall (plasterboard). Alternatively, there are special wall attachments that further increase stability.
Careful planning is crucial here to minimize risks—especially when children live in the household.
I would like to take a systematic approach to the topic of ensuring a stable footing on uneven floors for MALM furniture.
First: Most MALM furniture comes with simple plastic adjustable feet that can only compensate for minor irregularities in height.
Step 1: Measuring
Use a spirit level and, if needed, a long straightedge to check the floor where the furniture will be placed. Identify where the largest gaps are under the feet. This will help you determine how much leveling is required.
Step 2: Leveling
For smaller gaps, I recommend using self-adhesive rubber pads or felt pads, which can be stacked under the feet multiple times. For larger gaps, adjustable furniture glides or wedges made of plastic or wood work better. These provide more stability and also protect the floor.
Step 3: Stabilizing
Because MALM furniture is often quite tall and narrow, securing it to the wall is essential. However, be aware that different wall types have different load capacities. For drywall or lightweight walls, make sure to use special anchors designed to safely hold the weight.
Step 4: Safety check
Gently rock the furniture at the corners – there should be no noticeable wobble. If you still feel movement, adjust or add more leveling materials as needed.
In summary: leveling between the floor and furniture combined with wall mounting is the best approach.
Feel free to ask if you have any questions! 🙂
Step 1: Measuring
Step 2: Leveling
Step 3: Stabilizing
bulanau schrieb:
MALM furniture comes with simple plastic adjustable feetThis is correct and important because these feet do not provide flexible height adjustment or automatic leveling. If the floor is uneven, the system creates load concentrations that make the furniture unstable.
An effective method to securely and permanently fix MALM furniture on an uneven balcony floor is:
1. Precise leveling using small shims, such as plastic wedges or wooden shims. These should be impact-resistant and non-slip.
2. Ensuring that the feet rest not only on the shims but also have sufficient grip on the floor (no smooth surfaces).
3. Securing the furniture using the wall fasteners provided by the manufacturer. These provide essential protection against tipping, which is especially important if there are small children.
Alternatives like adjusting the feet or retrofitting height-adjustable furniture feet do not significantly reduce the effort if the wall fasteners are installed correctly.
Overall: Securing against tipping with wall fasteners is not optional if stability is to be ensured.
