ᐅ How can I securely install Ikea Pax wardrobes in an older building?
Created on: 8 Dec 2024 07:34
marcus
Hello everyone, I am planning to securely fix an Ikea Pax wardrobe in my older apartment, but I have concerns about the old wall structure. The walls are mostly solid masonry, partially covered with plaster, and in some areas uneven. My question is: What fastening methods are recommended to anchor a Pax wardrobe solidly and safely in an older building without damaging the wall or compromising stability? Are there specific anchors or techniques that have proven effective, especially for older masonry walls? Any advice on preparation, such as avoiding cracks in the plaster or choosing the right mounting height, would also be greatly appreciated. Thanks in advance!
marcus schrieb:
I think metal or heavy-duty anchors would be suitable here, but I'm a bit concerned about the crumbling areas. Should I repair these first, and if so, with which material to ensure a long-lasting fixing?I would definitely stabilize the crumbling plaster areas using a mineral-based repair mortar. A simple, fine-grained lime plaster mortar without additives works well. Avoid using synthetic fillers, as they might not be compatible with the wall. Allow it to dry completely before mounting (at least 3 days under normal conditions).
Additionally, I recommend drilling a hole slightly smaller than the anchor size to ensure a secure hold. If there are problematic spots, consider using injection resin anchors if the budget allows—they provide maximum grip in porous walls.
How large is the Pax wardrobe and how much weight does the wall need to support? This also plays a major role in choosing the anchor size.
Palenar schrieb:
How large is the Pax wardrobe and how much weight does the wall need to support?The Pax measures about 236 cm (93 inches) in height, 100 cm (39 inches) in width, and approximately 60 cm (24 inches) in depth. Fully assembled, it probably weighs around 80-90 kg (175-200 lbs); with contents, obviously more. I want the wall mounting to ensure stability, especially to prevent tipping – my main concern is having children in the household, so I am being cautious. I believe the combination of support at the bottom and anchoring at the top is crucial to prevent tipping, right?
flo-Theres9 Dec 2024 10:02marcus schrieb:
I think the combination of the lower support and upper fastening is crucial for preventing tipping, right?That’s correct. A secure lower support bears the weight and prevents slipping. The upper fastening counteracts tipping. Additionally, make sure the cabinet is installed level and flush to avoid assembly and usage problems. The fixing points should also be chosen on the firmest possible wall areas.
One last tip: If you’re unsure when drilling, it’s best to use a hole saw with a depth stop to avoid causing deep damage. It is also possible to set the wall plugs a bit deeper and improve their load capacity with adhesive for wall plugs. However, this should only be done by experienced DIYers. It is important that the cabinet is finally secured to the wall using the IKEA safety fittings, as this significantly reduces the risk of it tipping over.
