ᐅ How can I securely attach the Malm bed headboard?
Created on: 20 Feb 2023 08:37
BRANDONDAN
BRANDONDAN
20 Feb 2023 08:37
Good morning everyone,
I have an IKEA Malm bed with a simple headboard that I would like to secure more firmly. Currently, the headboard is only attached to the bed frame with the included screws, but it feels a bit wobbly to me.
My question is: How can I fasten the Malm headboard so that it is really stable and does not wobble or loosen when the bed is moved? Are there any proven methods or additional materials you would recommend? I would also appreciate tips on whether screws should be replaced or supplemented, or if another fastening technique has worked well.
I want to make sure everything holds up in the long term, as I would prefer not to have to adjust it again after a few weeks. Thanks in advance for your experience and advice!
Siflo
20 Feb 2023 11:19
to securely attach the headboard of your Malm bed, I recommend first replacing the existing screws with longer and stronger wood screws, as long as the material allows. It is important to keep the screw diameter compatible to avoid splitting.
Additionally, metal angle brackets can be installed on the inside at the connection points to improve load distribution. These significantly increase stability, especially if the headboard is a weak spot.
Another option is to apply wood glue on the joint surfaces to reinforce the connection slightly. However, this mainly supports durability rather than improving fixation.
In summary: better screws, angle brackets, and optionally wood glue are the common and effective methods for securing the Malm headboard.
JAFUHAU
20 Feb 2023 13:47
Hi!
I’m very familiar with this problem because I once had a Malm bed where the headboard often wobbled – it can be really annoying.
Siflo schrieb:
Attach metal angle brackets from the inside at the connection points to improve load distribution.
I can only confirm this! I did exactly that, and now the headboard is rock solid. Additionally, I added washers to the screws so they wouldn’t spin in the material.
Siflo schrieb:
Wood glue at the joint surfaces,
Wood glue sounds good at first, but it didn’t help in my case because the bed is also subjected to movement. The mechanical connection made the difference. You might also want to check whether the threaded inserts in the frame are still tight, as these sometimes loosen over time.
If you’re a bit handy, I also recommend using longer screws and sturdy nuts if the bed frame allows it – you can still improve things with the Malm.
GiRoyce
21 Feb 2023 07:06
I really appreciate that you are discussing different methods. For those who don’t know yet: The Malm bed is made from MDF panels with a melamine-coated surface, which makes screwing in with the wrong screws quite tricky – splitting or cracking can occur.
Therefore, I recommend:
1. Pre-drilling with a thinner drill bit that is properly sized to prevent the panels from splitting.
2. Using particleboard screws designed specifically for these materials, which have a special thread that provides strong holding power.
3. The corner brackets mentioned here are a great addition. However, you should attach them on the non-visible sides of the headboard.
4. If the bed is placed directly against the wall, you can also fix the headboard to the wall with small brackets, adding extra stability, especially if you often lean against the headboard.
It is important to screw in slowly and check the material while doing so.
Good luck reinforcing your bed’s headboard!
BRANDONDAN
21 Feb 2023 12:43
Thank you very much for the detailed tips so far!
For additional information: my bed is freestanding in the room, so unfortunately I can’t attach it directly to the wall with brackets. The idea of using longer screws and metal brackets sounds interesting.
If I connect the brackets on the inside, do you think simple metal brackets are enough, or should I use special furniture brackets?
I’m also wondering if I should make any changes to the screws themselves – for example, larger heads, different materials, or something like that?
I will definitely try the chipboard screws. What about using knock-in nuts to attach the headboard? Is that advisable for a piece of furniture like this, or is it rather risky?
I appreciate any shared experiences!
PULAU
21 Feb 2023 14:05
BRANDONDAN schrieb:
If I join corners on the inside, do you think simple metal brackets are enough, or should I use special furniture brackets?
For your purpose, I recommend sturdy steel furniture brackets with a wall thickness of at least 2-3 mm (0.08-0.12 inches). These are specifically designed for furniture construction and can handle higher loads than standard flat brackets from a general hardware store.
BRANDONDAN schrieb:
What about using knock-in (threaded) insert nuts to attach the headboard?
Knock-in insert nuts can be very useful if you want to secure from multiple sides, especially with thinner panels. However, you need to work precisely and pre-drill as necessary to ensure the inserts fit perfectly. This provides a stronger hold than regular screws alone.
A tip: Using insert nuts together with machine screws gives you the option to disassemble the headboard later without damaging the particle board.
In summary:
- Furniture brackets made from slightly thicker steel
- Use insert nuts if you can install them cleanly
- Appropriate particle board screws
This approach should give you a much more stable connection.
