Hello everyone, I recently got the Ikea Platsa system and want to securely attach some accessories to it. Specifically, I’m looking to install drawers and hanging cabinets as firmly and permanently as possible, so they don’t wobble or come loose during use. Are there any special tips for properly using the included screws and wall plugs? What types of wall fixings are recommended, especially when dealing with different wall materials like concrete or drywall (plasterboard)? And how can I install the accessories in a way that maintains the modularity of the Platsa system without making future modifications difficult? I look forward to your experiences and recommendations!
For concrete walls, always use high-quality anchors, preferably metal anchors. For drywall, it is recommended to use hollow wall anchors or specialized drywall anchors. Always tighten screws firmly but avoid overtightening. The fasteners provided by Ikea are acceptable, but for greater stability, I would recommend opting for higher quality.
The mounting of Ikea Platsa accessories primarily depends on the wall type and the intended load. It is important to first assess the load-bearing capacity of the wall. For drawers and hanging cabinets, which can become quite heavy, I recommend using expansion anchors in concrete and metal-clamp cavity anchors in drywall. Before drilling, marking with a spirit level is essential to avoid incorrect installation. Additionally, screws should be countersunk into the designated mounting points of the Platsa profiles and tightened with appropriate force to prevent damage to the material. Regularly checking that the screws remain securely fastened will extend the lifespan of the furniture.
Another important safety aspect is considering the maximum load capacity of the wall mounting. Ikea Platsa is modular, but each accessory has a specified load limit set by the manufacturer. It’s important to adhere to these limits to avoid damage. I also recommend not relying solely on the supplied fixings but using higher-quality screws and wall anchors, especially if the furniture will be heavily used or if there are children in the household. For drywall (plasterboard) walls, metal hollow wall anchors are advisable because they can carry a high tensile load, while simple plastic anchors are generally less secure.
