I recently purchased an IKEA Malm bed along with a matching desk. Now I’m facing the challenge of how to securely fix this furniture to my wooden floor without damaging it, while still ensuring enough stability so nothing slips or tips over. I’m especially interested in which methods or products you would recommend for effectively securing MALM furniture—particularly considering the carcass material and construction—onto solid wood or laminate floors. Are there specific fasteners that can be used, or would a combination of anti-slip materials and screws be advisable? Additionally, any advice on how to achieve a secure yet removable solution in rental apartments with delicate flooring would be appreciated.
Thank you for your tips!
Hello uwedo,
regarding your question about how to securely fasten MALM furniture on wooden floors, I recommend the following approach:
1. Non-slip pads: Place felt pads or special anti-slip mats designed for wood and laminate floors under the furniture. These prevent both scratches and slipping.
2. Floor attachment: If you want a permanent secure fix and the floor allows it, self-adhesive hook-and-loop pads or double-sided mounting tape can help without leaving marks. For more solid solutions, small angle brackets or furniture anchors screwed into the floor are possible but only if drilling is permitted.
3. Furniture connection: Since MALM furniture is usually made of particleboard with veneer, metal furniture connectors or brackets can be attached to the sides and then screwed to a fixed base. Be careful not to damage the floor when doing this.
4. Alternative fixing methods: Non-slip pads made of rubber or silicone provide good grip and can be removed without residue. Rugs placed under the furniture can also help.
Typical mistakes include gluing directly with regular adhesives that leave residues or using overly large screws directly into particleboard without pre-drilling.
In summary: For rental apartments, a combination of non-slip pads and possibly low-tack adhesive tapes is recommended. For owned property, additional fixing with brackets and screws is possible if the floor permits.
I hope this helps you!
klo40 schrieb:
Non-slip underlays and self-adhesive Velcro pads or double-sided mounting tape help...In addition, I specifically recommend using felt-backed rubber pads for wooden floors, as they both distribute pressure and increase friction, effectively reducing slipping. For a secure hold without damaging the floor, furniture clamps that grip between the furniture and the wall are advisable. These are reversible and leave no marks on the floor.
klo40 schrieb:
Caution: Do not damage the floor in the process.This is an important point: screws are not recommended, especially on solid wood floors, as they leave dents and holes. Moreover, in rental properties, drilling hooks or screws is often legally discouraged.
If permanent fixation is still necessary, I suggest using furniture anchors with adhesive backing designed specifically for wooden floors and removable without traces. This way, you can avoid future damage and hassle when moving out.
uwedo schrieb:
I am particularly interested in which methods or products you would recommend for securely attaching MALM furniture – especially the carcass material and construction – to solid wood or laminate floorsHello uwedo,
I fully agree with the tips already mentioned and would like to add a few more suggestions:
MALM furniture is often made from particleboard with a melamine surface or veneer, so it’s important to handle fastening carefully to avoid material chipping. Be sure to pre-drill before screwing and use high-quality screws.
For wooden floors, I would first try protecting the floor by adding felt pads that are both protective and non-slip. If the furniture has an option for wall mounting, definitely use it with angle brackets; these significantly help prevent tipping or sliding.
For rental properties, it’s also worth considering adjustable rubber-tipped furniture feet that can be firmly set to the floor while stabilizing the furniture.
Additionally, if you want to secure the furniture without drilling, try heavy-duty self-adhesive rubber pads. They can support the weight without leaving marks.
I hope these recommendations help you feel confident about fastening your furniture securely.
