Mu-ibrahim26 Sep 2023 18:27Hello everyone,
I am currently planning to equip my kitchen with IKEA Metod wall cabinets, but I am still unsure about the best and safest way to mount them on the wall. My main concern is the load-bearing capacity for normal use as well as the correct installation to ensure the cabinets remain stable over time—especially when storing kitchen items like pots or storage containers.
The IKEA assembly instructions include some information about the supplied mounting hardware, but I am wondering:
- Are the IKEA mounting materials sufficient for different types of walls (e.g., concrete, drywall with metal studs, or brick)?
- Is additional hardware such as wall anchors or plywood sheets behind the wall necessary for heavy cabinets?
- How important is precise leveling and the use of a spirit level or laser level during installation?
I have basic DIY skills, but when it comes to wall cabinets, I don’t want to take any risks. Who has experience with securely mounting IKEA Metod wall cabinets and can offer advice on what to really pay attention to?
Nathanaelk26 Sep 2023 21:03Hello Mu-ibrahim,
First of all, I find your question very well structured, and it’s important that you consider the wall types and loads. When securely mounting the IKEA Metod wall cabinets, several factors must be taken into account:
- Wall composition: For concrete walls, the included anchors are usually sufficient. You should use high-quality expansion anchors or, even better, metal heavy-duty anchors. For drywall, it depends on whether it is simply gypsum board or a metal stud framework. In the case of plain gypsum drywall, the anchors are often too weak; I recommend either special cavity anchors (e.g., metal toggle bolts) or screwing directly into the studs, ideally behind a plywood panel to distribute the load.
- Mounting hardware: IKEA often supplies basic plastic anchors and screws, which are adequate for most solid walls. For higher loads, I advise using your own screws with a larger diameter and suitable anchors. Eye bolts or threaded rods with professional fastening materials can also be useful.
- Loads and distribution: The wall cabinets should always be mounted flush with each other and screwed at least at two points per cabinet. This helps to distribute the load better across the wall.
- Alignment: Precise alignment is crucial. Be sure to use a spirit level and, if available, a laser level to align the mounting rails exactly horizontally. Otherwise, there may be tilting or load peaks on the screws.
- Tips for the process: Mark the holes with a pencil, pre-drill, and check the wall behind—it may contain cables or openings you need to avoid. After attaching the mounting rail, check if it is securely fixed before hanging the cabinets.
I hope this gives you a good overview. What type of wall do you have exactly? That would be an important detail for more specific advice.
Nathanaelk schrieb:
With drywall, it depends on whether it’s a plain gypsum wall or one with a metal stud frame.This is a crucial point that I can confirm myself. I recently mounted my Metod wall cabinets on a drywall surface and initially underestimated how delicate the construction is. At first, I only used standard anchors and screws — and after a short time, I noticed slight shifts, which worried me.
What helped me back then was installing a plywood panel behind the drywall, which I fastened to the load-bearing stud framework. The cabinets now hang completely securely, and I feel much more confident. This solution requires more work but is worthwhile as a long-term investment in the kitchen.
The sense of safety and the concern that something might eventually give way played a big role for me. I would recommend erring on the side of caution here, especially if there are children in the house or if heavy items will be stored.
Does anyone have a clear recommendation on which type of anchor offers the best combination of safety and ease of use? And how do you handle this in rental apartments where wall modifications are limited?
For drywall (plasterboard): always use metal toggle anchors, they hold best.
For concrete: heavy-duty anchors, not the cheap plastic plugs.
A plywood board is definitely worthwhile for light drywall installation.
The mounting profiles from IKEA are good, but the right screws are more important.
Mu-ibrahim schrieb:
My focus is specifically on load-bearing capacity under normal use and also on correct installation to ensure the cabinets remain stable over timeYou’ve summarized it very well, and in my opinion, this is the most important aspect. A secure installation doesn’t just mean attaching the cabinets to the wall somehow; it means mounting them in a way that they can withstand everyday loads.
I recommend checking the following before installation:
- Identify the wall type and whether there is a load-bearing element behind it (concrete, brick, metal studs).
- Verify that the existing anchors and screws are strong enough to support the weight, including the contents of the cabinets.
- For very lightweight masonry or drywall, always use additional reinforcement, such as a plywood panel.
Also keep in mind:
- Always use a cable detector before drilling to avoid electrical cables or water pipes.
- Cabinets should ideally be hung directly on a load-bearing profile; IKEA mounting rails make this easier.
- Use the full mounting set and, if necessary, replace screws with ones of the correct size.
A tip from experience – take your time to align the supports carefully and use a good spirit level. A misalignment of just 1–2mm (0.04–0.08 inches) can cause big problems when hanging the cabinets later.
Are there any specific wall areas in your kitchen where you’re unsure about the load-bearing capacity?
