ᐅ How can I securely mount IKEA Metod wall cabinets to drywall?
Created on: 27 Jan 2021 08:23
GeElias10
Hello everyone, I am planning to install several IKEA Metod wall cabinets on drywall in my apartment. My specific question is: How can I securely mount IKEA Metod wall cabinets on drywall so that both the weight of the cabinets and their contents are reliably supported over time without damaging the drywall? Which fasteners are best suited for this – for example, special anchors, mounting rails, or additional reinforcements behind the drywall? I would appreciate detailed advice on the procedure, necessary materials, and any common mistakes to avoid. Thanks in advance!
As a supplement: If you cannot reach load-bearing studs in drywall and creating an opening for a cross brace is not possible, I recommend using special heavy-duty metal anchors (e.g., toggle bolts or hollow wall anchors) that provide high load capacity. Make sure the anchors are fully expanded in the anchoring area. For IKEA Metod wall cabinets, the anchors should have a minimum load capacity of 50 kg (110 lbs) per anchor to ensure safety.
It is also important to distribute the fastening points evenly along the mounting rail to avoid point loads.
