ᐅ How can I securely mount IKEA Metod wall cabinets to drywall (also known as plasterboard or gypsum board)?
Created on: 18 Jul 2021 09:17
BarglaHello everyone, I plan to install several IKEA Metod wall cabinets in a kitchen on drywall. Since the cabinets are relatively heavy, I want to ensure the installation is as secure as possible and avoid any risks caused by unstable mounting. My question is: which methods and fasteners are truly recommended and reliable for mounting IKEA Metod wall cabinets on drywall? Has anyone had experience with special anchors, additional reinforcements, or alternatives such as hanging on mounting rails behind the wall? I would appreciate detailed advice, including tips on weight limits, drill bit diameters, and best practices for drywall installation.
It is best to use special drywall anchors or cavity anchors that have a high load capacity. It is important to screw the screws deep enough into the anchors and to keep the distance between the fixing points as wide as possible. Alternatively, you can screw a substructure made of wooden battens behind the drywall into the wall studs and hang the cabinets on that.
I would like to provide a more detailed guide on how to safely mount Ikea Metod wall cabinets on drywall. First of all: the drywall itself does not support the weight; the mounting solution must be anchored in the structure behind it.
- Use a stud finder or a magnet to check whether there are wooden or metal studs behind the drywall.
- Whenever possible, screw directly into these studs, ideally using long screws (at least 6 cm (2.4 inches) beyond the drywall surface).
- If there are no studs in the right area: use heavy-duty hollow wall anchors (anchors with metal expansion sleeves or toggle wings) or special spring toggle anchors that spread behind the wall and can carry high loads.
- Place drill holes precisely and before inserting anchors, reinforce the empty spaces with some foam sealant or wooden battens for additional stability.
- Ikea Metod cabinets have specific mounting rails on the back panel. Make sure the screws securely engage these rails.
Another option is to install an additional wooden batten substructure fixed to the drywall, which helps to distribute the weight more evenly.
My tip: consider not distributing the entire load to the wall alone, but also support it through a countertop or wall panels.
Common mistakes include: using anchors that are too small, ignoring the studs behind the drywall, or driving too many screws only into the drywall itself.
naujon schrieb:
The drywall itself does not bear the weight; rather, the fastening solution must be anchored in the underlying structure.This sounds to me like a really important distinction that not everyone immediately understands. I have personally experienced a cabinet coming loose after a few months because I only used standard anchors. That was frustrating and showed me that it’s better to be safe, especially with kitchen cabinets where there is always load from use and filled cupboards.
At the time, I was also worried about complicated fastening methods, but it’s better to put in a bit more effort than to have problems later. Also, I find it reassuring to know that the mounting is secure – even with Ikea Metod, I wouldn’t take any chances and would rather invest in good anchors or wooden battens.
Bargla schrieb:
Does anyone have experience with special anchors, additional reinforcements, or alternatives like hanging on installation profiles behind the wall?I wonder if insisting on drywall (gypsum board) makes sense at all. People often overlook that drywall walls are simply not designed to carry loads like these. Relying on cavity anchors here is somewhat risky.
A better approach would be to think completely differently: remove the drywall, install a sturdy wall reinforcement using OSB boards or solid wood panels, and then securely screw the cabinets into that. This would outperform any traditional screw-in-anchor solution.
But hey, if you really want to drill into a rigid, thin wall: use heavy-duty metal toggle anchors, not the simple plastic ones. And if the wall is extremely thin, don’t hang a cabinet run over 2.5 meters (8 feet) long — a controversial opinion, I know.
Alberto5120 Jul 2021 14:52Lisele schrieb:
I was also worried about complicated fastenings back then, but it’s better to spend some effort upfront than to face problems later.I can only agree! Last year, I installed the Ikea Metod cabinets on drywall and took my time checking how the anchors held. My solution was a combination of metal toggle bolts and an additional wooden batten behind the drywall, which I fixed between the studs. It cost me more work than expected, but today I’m very confident that the cabinets won’t fall down.
So folks, invest some patience and protect your walls from stress. Sometimes it also helps not to concentrate the weight in one area but to distribute it across several points.
