ᐅ How can I securely mount Ikea Metod wall cabinets to concrete walls?
Created on: 27 Jun 2022 08:37
philippvinP
philippvin27 Jun 2022 08:37Hello everyone,
I am currently planning a project to mount several IKEA Metod wall cabinets on a concrete wall and want to ensure maximum safety and stability. The concrete wall is solid and should reliably support the cabinets permanently – this is not just for simple kitchen units but for full load-bearing with contents, including heavier items like dishes and appliances.
My main question is: Which anchors and screws are best suited for mounting IKEA Metod wall cabinets on concrete walls? Are there particular procedures for pre-drilling, inserting anchors, and screwing that have proven effective?
I am also interested in whether it is advisable to use additional safety measures such as screw anchors or clamping profiles, and what to consider regarding the distribution of the load.
Thanks in advance for your tips and experiences!
Hello philippvin,
First of all, great job on your very clearly formulated question! It makes advising much easier.
Here is my suggestion in several steps:
- Choosing anchors: For concrete walls, I recommend high-quality heavy-duty anchors, such as concrete expansion anchors or chemical anchors. For heavy wall cabinets, metal screw anchors are usually the most secure option.
- Screws: Make sure the screws match the type of anchor and have sufficient length (drill hole + anchor length + thickness of the cabinet back panel).
- Pre-drilling: Use a high-quality hammer drill bit that is precisely matched to the anchor diameter. Drill to a depth about 10mm (0.4 inches) deeper than the anchor to allow full insertion.
- Installation: Gently tap the anchors in with a hammer, then align the cabinet and slowly and evenly tighten the screws.
- Load distribution: The cabinets should be supported on multiple fastening points, at least 3 per cabinet, preferably 4 (top and bottom sides of the cabinet). If possible, connect the cabinets with mounting rails – this reduces stress.
- Safety measures: Chemical anchors can be used if especially high loads are expected. It is essential to verify the load capacity of the anchors on concrete, as a strong foundation is key.
Also, make sure to follow the IKEA assembly instructions carefully and not rely solely on the supplied fasteners. Different wall materials often require alternative solutions.
Hope this helps you!
I would recommend using 10mm (0.4 inch) hammer drill bits and 10mm (0.4 inch) heavy-duty metal anchors. The screws should be at least 70mm (2.8 inches) long to properly engage the anchor. Make sure to thoroughly remove the drill dust before insertion. Three to four fastening points per cabinet are ideal.
LOGEMIN schrieb:
You can use chemical anchors if especially high loads are expected.That is correct, but I would like to add: chemical anchors do indeed provide high load capacity, but they are more complex to install, more expensive, and often require appropriate curing times. In some cases, a traditional expansion anchor with a sufficient diameter and good embedment in the concrete can be just as secure – this should be assessed individually and based on the wall analysis.
I also recommend checking the actual load of the wall cabinets: only a few users load such cabinets very heavily, often simple heavy-duty anchors are sufficient.
Furthermore, it should not be forgotten that proper wall preparation, dust-free drilling, and following the manufacturer’s instructions play a more important role than simply choosing larger anchors.
Do you have any specific concerns regarding wall thickness or installation conditions?
philippvin28 Jun 2022 16:27faso31 schrieb:
Are there any specific concerns about the wall thickness or installation conditions on your side?Thanks for asking! The wall is about 24 cm (9.5 inches) thick, solid concrete, with no cavities. The surface is fairly smooth but not glossy. I plan to use the cabinets for kitchen utensils, so I expect a moderate load, but definitely sometimes heavier dishes and spice jars as well. My main concern is that the cabinets won’t become loose or fall off over time because I underestimated the anchoring.
Do you have any tips on how to check if the screws are properly seated or if the anchors are gripping well? Is there a simple way to test this after installation?
Additionally, a range hood will be installed on one of the cabinet rows, which will be directly supported by attachments on the cabinet—this increases the stability requirements even further.
