ᐅ How can I securely mount Ikea Metod shelves on different types of walls?
Created on: 3 Oct 2024 08:17
tasiken
Hello everyone, I’m planning to install several Ikea Metod cabinets in my apartment and want to make sure I correctly handle the wall mounting. The challenge is that I have different wall types in the rooms: for example, drywall (plasterboard), concrete, and also older brick walls.
I’m particularly interested in which mounting methods and types of anchors are best suited for securely and safely fixing the Metod cabinets to the wall without risking damage. Are there any specific considerations to keep in mind, such as maximum load, types of screws, or mounting rails?
I would appreciate a detailed explanation. The focus is not only on stability but also on safety, to ensure the cabinets won’t fall off the wall. Thanks in advance!
I would like to summarize some basic recommendations here to provide a reliable guideline for anyone who feels uncertain.
1. Identify the wall type: drywall (gypsum board), concrete, or brick? When in doubt, test with a drill or a suitable device.
2. Choose the appropriate anchor type: hollow wall anchors for drywall, heavy-duty anchors for concrete, and chemical anchors if the bricks are porous.
3. Drill the hole precisely: the drill diameter must match the anchor exactly; otherwise, the fastening will lose its hold.
4. Increase the number of mounting points: Metod shelves have a mounting rail – use all the fastening holes.
5. Avoid overloading drywall walls: their maximum load capacity is significantly lower than that of concrete or brick.
If you have trouble accurately identifying the wall, keep in mind that often multiple layers (drywall over brick) can affect the choice of fasteners.
I hope this summary helps everyone who feels unsure about the Ikea Metod installation.
I really appreciate how many people here are already sharing practical tips. I want to emphasize safety again: For shelves like the Metod systems, it’s really important not to rely solely on the screws provided by Ikea, but to consider using high-quality anchors and screws from a hardware store.
Additionally, I recommend checking the wall behind the drywall (plasterboard) with a multi-detector to avoid hitting pipes, cables, or metal studs. This improves safety and protects the installation.
Sometimes it also helps to do a test mounting at a lower height to make sure the anchors hold properly before attaching the shelf permanently.
BARSAN schrieb:
- Drywall: Molly bolts
- Concrete: Metal heavy-duty anchors
- Brick: Chemical anchors or heavy-duty anchorsThank you for the clear summary; it helps me a lot as a guideline.
I am also curious: Is there any rule of thumb for how many fixing points per meter of shelving should be used to distribute the load optimally? I have planned a longer run of shelving and want to make sure that the wall and the material are not overloaded.
Thanks to everyone here for the helpful tips so far!
