ᐅ How can I securely mount Ikea Metod shelves on different types of walls?
Created on: 3 Oct 2024 08:17
tasiken
tasiken
3 Oct 2024 08:17
Hello everyone, I’m planning to install several Ikea Metod cabinets in my apartment and want to make sure I correctly handle the wall mounting. The challenge is that I have different wall types in the rooms: for example, drywall (plasterboard), concrete, and also older brick walls.
I’m particularly interested in which mounting methods and types of anchors are best suited for securely and safely fixing the Metod cabinets to the wall without risking damage. Are there any specific considerations to keep in mind, such as maximum load, types of screws, or mounting rails?
I would appreciate a detailed explanation. The focus is not only on stability but also on safety, to ensure the cabinets won’t fall off the wall. Thanks in advance!
flo-Theres
3 Oct 2024 09:03
The question is very well posed and highly relevant, especially considering the different types of walls.
For drywall (plasterboard) walls, I generally recommend using special cavity anchors or molly bolts, which expand behind the board. Standard anchors are usually not suitable here, as they do not provide enough grip.
For concrete walls, traditional heavy-duty anchors or expansion bolts can be used. An important point here is precise drilling with a hammer drill and the correct drill bit diameter for the anchor.
For brick walls, heavy-duty anchors with optimal expansion should be preferred. If the bricks are hollow or porous, chemical anchors (injection mortar) can alternatively be used to achieve a secure hold.
Another tip: The Metod shelves have a mounting rail at the top that is fixed at several points – distribute the screws so that the load is spread evenly across the wall, rather than concentrated in just a few spots.
nolan
3 Oct 2024 09:15
For drywall: use hollow wall anchors.
For concrete: use heavy-duty anchors and a hammer drill.
For brick: use heavy-duty anchors or chemical anchors. Distribute screws across multiple points.
Lorukeo
3 Oct 2024 10:41
In addition to the previous explanations, here is a structured overview:
- Drywall: Use hollow wall anchors (e.g., metal molly bolts or plastic expansion anchors) to prevent pull-out. Maximum load is usually around 15-20 kg (33-44 lbs) per anchor.
- Concrete: Heavy-duty metal anchors with the correct diameter are required. Drill holes must be clean and properly sized. Loads of 50 kg (110 lbs) or more are possible.
- Brick: Depending on the condition of the bricks (solid or hollow), either heavy-duty anchors or chemical anchors should be used. For older or porous bricks, chemical anchors are the safer option, as they provide strong holding power through curing.
Mount shelves with multiple fixing points to distribute the load evenly, reducing the risk of wall damage and increasing safety.
Additionally, I recommend checking the load capacity of the specific material on site and observing the manufacturer’s load specifications for the anchors used.
KNUTGI
3 Oct 2024 11:24
flo-Theres schrieb:
The Metod shelves feature a mounting rail at the top, which is secured at multiple points – distribute the screws so that the load is evenly spread across the wall and not concentrated in just a few spots.
Exactly! And I would also recommend, especially with drywall, not to overload the shelves. It’s better to install more shelves more frequently with smaller loads – this prevents the dreaded pull-out of the anchors.
A small tip for everyone: always drill the holes using an appropriate drill bit (e.g., a masonry bit for concrete, a wood bit won’t work here). This helps avoid unnecessary cracks and wall damage. When combined with the right anchor, you get genuine holding strength.
warrenka57
4 Oct 2024 07:55
Hello everyone, I was unsure myself about how to attach my Metod shelf to my old brick wall. The wall was porous, and at first, I was hesitant to use chemical anchors. After a few attempts with regular heavy-duty wall plugs, they all eventually pulled out.
My advice based on experience: it’s better to go with chemical anchors, even if it’s a bit more work. The safety is simply much higher.
Also, I installed the shelves gradually and never loaded them too heavily, which prevented any issues.
Don’t feel bad if it doesn’t work perfectly at first – I also learned through trial and error.
