ᐅ How can I securely attach IKEA Metod kitchen cabinets to drywall (plasterboard) walls?
Created on: 30 Jun 2022 14:38
Floan
Floan
30 Jun 2022 14:38
Hello everyone, I am planning to install an IKEA Metod kitchen on a drywall (plasterboard) wall, but I am unsure about the best way to ensure a secure and stable mounting.
The wall consists of double-layer drywall on a wooden framework, and the cabinets will be fitted partly with fronts and partly with heavy appliances. I am concerned that standard anchors or screws may not be sufficient to support the weight long-term without damaging the wall or causing the cabinets to come loose. Does anyone have experience with which fastening methods or materials have proven reliable in such cases? Are there special anchors, screw techniques, or reinforcements that can be used?
I look forward to tips, recommendations, and any advice on preparing the wall or distributing the load of the Metod units.
Mufato
30 Jun 2022 15:22
Use heavy-duty anchors for drywall, such as metal toggle anchors or hollow metal anchors. It is important to fasten them to the supporting wooden framework, not just the plasterboard. Alternatively, you can secure the furniture to the wall using an additional wooden batten that is firmly screwed in place.
edisondan
1 Jul 2022 09:07
For secure mounting of IKEA Metod kitchen cabinets on drywall, I recommend the following procedure:
- First, fastening should preferably be done on the load-bearing wooden studs behind the drywall. This significantly increases load capacity.
- If the cabinet hangers do not align directly with the wooden framework, installing cross battens fixed to the studs provides a stable base for cabinet installation.
- When using anchors, be sure to use approved metal hollow wall anchors that offer higher load capacity, such as toggle bolts or metal hollow wall anchors.
- The exact number and spacing of fastening points are crucial; a cabinet about 80cm (31.5 inches) wide should have at least three fastening points to evenly distribute the load.
- Finally, make sure all screws are set deep enough without damaging or cracking the drywall panels.
These recommendations are based on standardized fastening techniques for light to medium loads on drywall partitions.
O
olivernu
2 Jul 2022 17:53
Floan schrieb:
Does anyone have experience with fastening methods or materials that have proven effective in such cases? Are there specific anchors, screwing techniques, or reinforcements that can be used?
I can add that using mounting battens is an elegant solution for drywall (gypsum board) walls. In this method, a sturdy wooden batten is fixed to the existing wooden framework behind the drywall panel. The Metod cabinets are then securely attached to this batten.
This technique provides better load distribution and reduces the risk of damage to the drywall. Additionally, I recommend using screws with the appropriate diameter and anchors designed specifically for wooden substructures for all screw connections.
It is also important to consider the maximum load capacity of the individual Metod components, which should be factored into the installation. For particularly heavy appliances such as dishwashers or ovens, additional floor mounting can be helpful to keep static loads manageable.
