ᐅ How can I securely attach IKEA Metod kitchen cabinets to drywall (plasterboard) walls?
Created on: 20 May 2022 18:37
Neoben
Neoben
20 May 2022 18:37
Hello everyone, I am currently planning my new kitchen with IKEA Metod cabinets and have a drywall (plasterboard) wall as the base for the wall cabinets. I understand that drywall is not as load-bearing as solid walls, so I am looking for proven and reliable methods to securely and permanently attach the Metod wall cabinets to drywall. I am especially interested in which types of anchors work best and if additional reinforcements are necessary, how to properly distribute the load, and whether a support batten behind the drywall panel is required. Has anyone had experience with this approach and can provide specific tips on what to watch out for to ensure stability? Thanks in advance!
Taubi
20 May 2022 19:02
It is best to use special hollow wall anchors, such as metal molly bolts, and distribute the load as evenly as possible. If it needs to be load-bearing, make sure to install a battens or furring strips behind it.
Dirkmin
20 May 2022 20:14
For mounting IKEA Metod kitchen cabinets on drywall, I recommend the following approach:
- Check the wall thickness and whether there is a supporting batten or OSB board behind the drywall.
- If it is only drywall, be sure to install wooden battens (for example, 40x60 mm (1.6x2.4 inches)) behind the drywall to ensure a secure fixing.
- Use metal toggle bolts or molly bolts with the appropriate load capacity—ideally, not just anchors but also screws into the underlying battens.
- Distribute the cabinet load across multiple fixing points.
Without additional reinforcement, fastening solely to drywall is usually insufficient for heavy kitchen cabinets.
Kinbu
20 May 2022 21:07
Hello Neoben, I completely understand your concern because drywall partitions are convenient but do not offer high load-bearing capacity. If you want to attach wall cabinets directly to drywall, you should definitely consider the following points:
- Use hollow wall anchors rated for the weight. Metal molly bolts are often better suited than plastic anchors.
- Ideally, install a threaded screw into a wooden or metal stud behind the drywall before hanging. This can then be loaded through a suitable screw in the cabinet hanger.
- If you have the option to open the drywall panels: install a reinforcing batten or OSB board perpendicular to the wall to create load-bearing zones.
This way, you can ensure that your IKEA Metod system is securely mounted without the risk of the cabinet falling later.
teyosef
21 May 2022 08:53
Hello Neoben,
I would like to address the topic of mounting IKEA Metod kitchen cabinets on drywall (plasterboard) walls in detail and provide a brief guide.
1. Load Calculation and Preparation:
First, it is important to know the weight of the planned wall cabinets. An empty Metod cabinet weighs between 15 and 25 kilograms (33 and 55 lbs), plus contents often add 30 kilograms (66 lbs) or more.
2. Wall Assessment:
Is it just a single layer of drywall, or is there already a stable substructure? If it is only drywall, reinforcement is necessary.
3. Installing Reinforcement:
- Open the wall at the location where the cabinets will be mounted.
- Attach solid wood battens horizontally across the studs on the backside of the drywall, at least 40x60 millimeters (1.6x2.4 inches) depending on the load requirements. These serve as a secure mounting base.
- Close the wall again with new drywall.
4. Choosing the Right Anchors:
- If attaching only to drywall without additional reinforcement, long-term safety cannot be guaranteed.
- With reinforcement, standard wood or particle board screws can be driven into the wooden battens.
- If reinforcement is not possible, use metal toggle bolts with an appropriate load rating (at least 50 kilograms (110 lbs) per anchor).
5. Load Distribution:
Distribute multiple anchors per cabinet, at least four, preferably more. Shorter cabinets are better than very long ones, as they exert less bending moment.
6. Installation:
Metod cabinets are usually hung on a mounting rail. This rail must be securely fastened to the reinforced wall with appropriate fixings.
Conclusion: The best and most reliable solution is reinforcement behind the drywall using wooden battens. This ensures stability and allows for secure fastening of Metod screws.
Common mistakes are using insufficient anchors or relying solely on hollow wall anchors without any backing battens. This often leads to drywall failure under load.
I hope this guide helps you and others interested in this topic.
GALENKU
21 May 2022 09:18
Anchors such as metal anchors or toggle bolts are mandatory if there is no reinforcement. Make sure the cabinets do not become too heavy.
