ᐅ How can I securely attach Ikea Metod cabinets to drywall/plasterboard walls?
Created on: 12 Aug 2024 14:23
BIKOLIS
BIKOLIS
12 Aug 2024 14:23
I am currently facing the challenge of securely mounting various Ikea Metod kitchen cabinets on drywall. My wall is entirely drywall on wooden studs, and I want to avoid the cabinets coming loose over time or causing damage to the wall.
I am particularly interested in strong and long-lasting fixing methods. What types of anchors or fastening techniques are recommended specifically for Metod systems, and are there any practical tips for distributing the load?
Has anyone had experience with additional reinforcements, such as wooden battens behind the drywall, or special mounting methods to increase stability?
I would appreciate detailed advice, including personal experiences with methods that have proven effective in everyday use. Thanks in advance!
fredle
12 Aug 2024 16:41
Hello BIKOLIS,
I can understand your question well, as securely fastening Ikea Metod cabinets to drywall really requires careful handling.
I recommend the following approach:
- First, try to attach the cabinets directly to the wooden studs whenever possible, since drywall alone cannot reliably support the load.
- If the studs are not spaced appropriately, it is advisable to install a horizontal or vertical wooden batten (at least 40x60 mm (1.5x2.4 inches)) behind the drywall. This helps distribute the weight better.
- For mounting the cabinets, use at least heavy-duty anchors or special hollow-wall anchors designed for drywall (e.g., metal anchors or toggle bolts with high load capacity).
- Make sure the anchor length matches the wall thickness and that the diameter is at least 6-8 mm (0.24-0.31 inches).
A common mistake is using simple plastic anchors, which can fail quickly under load.
Additionally, if possible, you should attach the Metod base plates to the battens or studs in a way that optimally distributes the weight.
Summary: Use a wooden batten for reinforcement and then high-quality heavy-duty anchors for fastening to the battens or directly to the studs. Otherwise, the loads are too high for standard drywall.
I hope this helps you!
likuken
13 Aug 2024 09:17
fredle schrieb:
A common mistake is using only simple plastic anchors, which can fail quickly under load.
I completely agree with you, but I think: why not install a solid support structure made of metal profiles or wooden battens behind the drywall right from the start? Most people underestimate the load from cabinets or assume that standard anchors are sufficient.
The latter is a misconception, especially for kitchen cabinets holding dishes or appliances. My approach would be that Metod cabinets should generally not be mounted on drywall alone without this reinforcement.
The Metod systems are not light, and the cycles of opening and closing as well as vibrations put significant stress on the substrate. Anyone who thinks it will work with simple anchors risks not only damage to the wall but, in the worst case, an accident.
To be provocative: the Ikea instructions are nice but actually inadequate for drywall because the exact support structure is insufficiently considered.
koduga
13 Aug 2024 11:54
likuken schrieb:
I’ll say it provocatively: The Ikea instructions are nice, but actually insufficient for drywall
You definitely have a point there. I understand if this uncertainty unsettles someone. It was new territory for me too until I did some reading.
I also want to add that the psychological aspect plays a role: You have to dare to reinforce the wall with wooden battens, even if at first you think, "That might look awkward" or "That will take extra time."
Of course, it’s more effort, but it’s better than dealing with falling cabinets and frustration later on.
In addition, I’ve had good experiences with loosely mounting the cabinets temporarily before final installation and gently testing them under load. That way, you quickly find out if it will hold or not.
With drywall, it should really always be a combination of reinforcement and appropriate anchors to have peace of mind in the long term.
benon
14 Aug 2024 08:35
I would like to add that besides mechanical fastening, it is also important to properly adjust and, if necessary, support the cabinets.
My tips:
- Use the wall mounting hardware provided by the manufacturer exactly as intended. Ikea often includes special mounting plates that distribute the weight more evenly.
- Check with a spirit level that the cabinets are hung straight, as units installed at an angle put more strain on anchors and the wall.
- For drywall (plasterboard) walls, I often install a reinforcement strip above the cabinets to reduce the tensile forces.
- For heavy cabinets or large units, it can be beneficial to transfer some of the weight to a substructure or the ceiling.
Any fastening on drywall remains a compromise solution if direct anchoring into a wooden or metal subframe is not possible.
A bit of planning in advance saves a lot of trouble later.
