ᐅ How can I securely fasten IKEA Besta units to walls made of different materials?
Created on: 29 Nov 2016 18:11
Leandro0Hello everyone, I want to securely and safely attach my IKEA Besta furniture to different types of walls. My apartment has concrete walls, but also some load-bearing drywall partitions and a lightweight stud wall made of wood. It’s important to me that the fixings not only support the weight of the cabinets but also remain reliably secure over time, without me having to worry about the units loosening or causing damage eventually. What specific fixings or installation techniques do you recommend for these different wall types? Are there differences in anchors, screws, or procedures that I should definitely be aware of? I look forward to detailed advice on the best way to carry out the installation, especially when dealing with variations in wall construction. Thanks in advance!
Rashadmeo29 Nov 2016 19:03Leandro0 schrieb:
What special fasteners or techniques would you recommend for these different types of walls? Hey Leandro0, that’s a great question!! 😊 Especially with IKEA Besta units, it’s really important to securely fix them to the wall to prevent any wobbling!
For concrete walls, I recommend strong metal anchors like heavy-duty expansion anchors or metal sleeve anchors – they hold very firmly! For drywall (plasterboard) walls, cavity anchors (also known as toggle bolts) are best; they open up inside the wall and spread the load over a wider area. This gives you great holding power without damaging the wall.
For lightweight partition walls, you should definitely try to screw into the wooden studs – that’s key for stability. If possible, you can use a small stud finder to locate the studs, or a small magnet to detect metal screws.
Remember to use enough fastening points to better distribute the load. And don’t hesitate to tighten the screws firmly; the IKEA material can handle it easily! Good luck – you’ve got this!
Leandro0 schrieb:
It is important to me that the mounting not only supports the weight of the cabinets but is also permanently reliable I completely understand, Leandro0. You don’t want to have to keep checking all the time and risk damage in the worst case.
When dealing with different wall types, the key is really using the correct anchors and screws. In my apartment, I have both concrete and drywall, and I use standard masonry drill bits plus metal expansion anchors for the concrete, and hollow wall anchors for the drywall.
One tip that helped me: always measure exactly where the wall studs are before screwing anything in. That saves you the hassle of having to drill again and ensures better support.
Are you planning to hang the cabinets individually or as a group? Sometimes that can create different stresses.
I hope my experience helps you a bit! Keep your spirits up, it will work out.
Cool topic here! 😎 Regarding "How do I securely attach IKEA Besta units to walls made of different materials?" – well, I’d almost say it’s like a dating game with walls: you just need to press the right buttons and provide the proper support.
Seriously: For concrete walls, you can use fairly large anchors (e.g., Fischer or Spax); the bigger, the stronger. In drywall (also known as plasterboard or gypsum board) walls, those toggle anchors that Rashadmeo mentioned are really brilliant – it sounds like you could hang cabinets from the ceiling with them! 😄 And for lightweight partition walls, the rule is simple: screw into the studs or timber behind the wall, otherwise it won’t hold.
Another tip from my experience: if you place the cabinets on floors with baseboards, you can drill through at the top before fastening and secure them at the very important ceiling-to-wall connection. That makes the installation rock-solid.
And hey, despite all the technical stuff: have some fun while you’re screwing everything in. Good luck!
Rashadmeo schrieb:
With lightweight partition walls, you absolutely need to try to place the screws into the wooden studs – that is the key to stability. Absolutely correct, there is no real alternative for lightweight partition walls. If you only screw into the drywall, it won’t hold for long.
Another option, if the cabinet isn’t too heavy, is to secure it with special furniture mounting profiles or wall mounting frames – the more contact points, the better.
For concrete walls, the rule is: never be stingy with drilling; better to drill a bit more holes using the appropriate heavy-duty anchors. For lightweight construction, always look for wooden studs, and for drywall, always use cavity anchors. It’s that simple.
bareynaldo1 Dec 2016 07:52Leandro0 schrieb:
Which specific fasteners or techniques do you recommend for these different types of walls? Are there differences in anchors, screws, or procedures that I should definitely keep in mind? Sometimes I wonder if all these "special" anchors and fastening systems are just a marketing gimmick. Of course, standard heavy-duty anchors work fine for concrete—that’s basic knowledge. Drywall and lightweight construction are a bit trickier—hitting the wooden studs is essential, yes, but how many DIYers actually manage to do that perfectly? In my opinion, the real issue is that people don’t think enough about load distribution and don’t use enough fastening points. Instead, they rely on some kind of high-tech anchors. Ultimately, even the best screw won’t help if the load isn’t well distributed.
So my advice: use more anchors, more screws, more fastening points, and it will hold. That’s it. I think the debate over hollow wall anchors versus heavy-duty anchors is sometimes too intense.
