ᐅ How can I securely fasten IKEA Besta units to different types of wall materials?
Created on: 6 Apr 2018 18:37
dalibenHello everyone, I plan to install an IKEA Besta shelving unit in my home, but I’m unsure how to securely fasten it to different types of walls. My main concern is the load capacity and the appropriate fastening method for various wall materials such as concrete, drywall (gypsum board), or even brick.
The IKEA instructions generally state that the unit should be attached to the wall but do not provide specific recommendations for different wall types.
My questions are:
- Which wall plugs and screws are best suited for concrete, drywall, and brick walls?
- Are there any special considerations when mounting the brackets, such as minimum distances or pre-drilling requirements?
- How can I prevent the shelving unit from falling off the wall under heavy loads, especially when storing heavy items?
I would appreciate detailed tips and experiences, especially if you know of alternative solutions that IKEA might not suggest. Thanks in advance!
My questions are:
Always use heavy-duty anchors for concrete and brick, preferably plastic or metal anchors with matching screws.
For drywall, special hollow wall anchors are required that expand or twist inside the wall. Standard anchors will not hold.
Pre-drilling is mandatory; choose the drill bit diameter according to the anchor size. Maintain minimum spacing for stability—at least 10 cm (4 inches) between screws.
Hello daliben, your concern is very important, as safety when installing Besta furniture should not be underestimated. I will expand on fojaix’s points in more detail:
- Concrete walls: Use high-quality expansion anchors or metal anchors that are approved for solid walls. Drill holes must be clean and made with a drill bit matching the size of the anchor. Screws should be long enough to provide sufficient support.
- Brick walls: Solid anchors are also necessary here; universal or specific brick anchors are suitable. Caution: For hollow bricks, verify that the anchors will hold; otherwise, use cavity anchors or chemical anchors.
- Drywall (plasterboard) walls: Since these are not load-bearing, cavity anchors such as toggle bolts or metal wing anchors are mandatory. Using screws specifically designed for drywall improves holding strength.
For fixing: Make sure that the mounting brackets or supports for the Besta furniture are secured with at least two screws each to distribute the load properly. The distance between the screws should not be too small; I recommend at least 10cm (4 inches), preferably more if the wall permits.
Additionally: Consider whether heavy loads on the top of the shelf can be supported by the floor rather than relying solely on wall mounting. If you store heavy items, distribute the weight evenly.
If you have more specific questions, I am happy to help.
daliben schrieb:
Which anchors and screws are best suited for concrete, drywall, and brick walls?For concrete walls, nylon-coated expansion anchors with matching screws are recommended. Alternatively, metal anchors also work very well.
daliben schrieb:
Are there any special considerations when installing the brackets, such as minimum distances or pre-drilling requirements that I should be aware of?Always pre-drill with a drill bit whose diameter exactly matches the anchor. This ensures optimal holding strength. Minimum spacing depends on the length and load capacity of the screws, but at least 10 cm (4 inches) apart is advised to maintain load-bearing capacity.
daliben schrieb:
How do you prevent the shelf from falling off the wall under heavy load?It is important that the fastenings are anchored in solid material. For drywall, this means fixing into the wall studs or using high-performance cavity anchors.
Additionally, you can plan a combination of floor-supported load distribution and wall mounting. This significantly reduces the static load on the wall anchors.
Conclusion: There are specifically designed fasteners for every wall type. The solutions presented are tested and provide maximum safety when properly installed.
