I am planning to securely fix several Billy shelves to the tiled floors in my living room because they tend to be a bit unstable on the smooth surface, and I am concerned about safety, especially with young children in the house. My question is: what is the best and most permanent way to stabilize Billy shelves on tiled floors without damaging the tiles? For example, I know of possible solutions using adhesives, screws, or special sliding or anti-slip mats, but I am unsure what is recommended for tiled floors. Are there proven methods or maybe even special tools or fasteners you would recommend? Thanks in advance for your help!
likuken schrieb:
Why not try modifying the shelves yourself a bit, for example by adding extra cross braces at the bottom or on the sides?That’s an interesting idea, thanks. I’m actually open to adjustments to the shelves themselves, just as long as the appearance isn’t changed too much. Cross braces sound doable, as long as they remain discreet in the lower area. Does anyone here specifically use such modifications? How exactly do the cross braces improve stability, and do you have any tips on material choice? Wood strips, metal?
Also, if the shelves are moved later, any changes should be easy to reverse.
Julia schrieb:
Does anyone use such modifications? How exactly do cross braces stabilize?Cross braces increase the torsional rigidity of the shelving unit. They prevent the shelf from swaying sideways, which is more common on smooth floors without anchoring. The best options are narrow metal brackets or wooden strips fixed diagonally or horizontally to the shelf frame.
Using screws for attachment is ideal because it provides a secure connection that can also be undone.
If you use wooden strips, I recommend hardwood (e.g., beech) in a slim profile so they don’t look intrusive. Metal brackets indoors often appear less elegant but are more stable.
For installation: It’s best to attach the braces to the inside of the shelf sides. And yes, the whole setup can be removed cleanly by unscrewing the screws.
In addition to wall mounting and modifying the shelves, you can also apply a thin layer of self-adhesive rubber mats on the shelf surface, which provides both anti-slip and vibration-damping effects.
Sometimes, compensating for slightly uneven tile heights with adjustable feet attached to the shelf helps as well – this ensures the shelf stands level and cannot tip over. Compared to drilling, this also saves considerable effort later on.
I know that uncertainty on smooth floors can quickly become stressful. I had a similar issue with my Billy shelves, which were always a bit wobbly. In the end, I decided to use a combination of anti-slip pads and wall anchoring. The feeling that the shelf is now secure really helped me feel calmer, especially when the kids visit :-).
It’s also important for me not to damage the floor, since we had the tile floor redone just a year ago. Therefore, no drilling into the floor and no permanent adhesives on the tiles. I can just confirm again what has already been said here: secure it to the wall, use soft anti-slip pads under the feet, and everything becomes stable.
