ᐅ How can I securely attach BILLY shelves to smooth walls?
Created on: 14 Oct 2023 09:37
Moarjen
I plan to mount my IKEA Billy shelves on a wall with a very smooth surface, something like smooth concrete or a skim-coated, smooth plaster. The wall seems to be hardly porous, which makes using conventional anchors and screws difficult.
My question is: which methods or special fastening materials are best suited to securely and permanently fix the shelves? I want to avoid the shelves slipping over time or not providing the necessary stability due to improper installation.
Also, I’m interested in any specific tips for preparing the wall, such as surface treatment measures, to help the fittings hold better.
I’m familiar with the standard anchors for concrete or hollow walls, but my wall doesn’t quite fit into those typical categories.
I would really appreciate detailed experiences, as well as advice on tools and techniques, and also tips on common mistakes to avoid.
Thanks in advance!
Wesley
16 Oct 2023 11:03
Hey,
Smooth wall mounting is always a bit of an adventure—I’d say you almost feel like a secret agent on a mysterious mission ;-)
Jokes aside, what really helps here is exactly what was already mentioned: chemical anchors. The little resin trick is truly a game-changer and the best investment for situations like this.
What I want to add is: be patient with the curing time. I know you want to load the shelf right away, but waiting a bit will save your nerves and protect your wall :-)
If you’re looking for a shortcut, don’t worry too much about small adjustments, but enlarging drill holes again is a no-go. Better, as anfeteo already suggested, to insert test screws before mounting everything.
Good luck, and feel free to show us if it worked out!
LEEJU
16 Oct 2023 16:22
A quick summary:
1. Use the appropriate concrete drill bit
2. Ensure the drill hole is clean and dust-free
3. Insert the chemical anchor
4. Allow to cure for 24 hours
5. Mount the shelf bracket
This will make the shelf very secure and stable.
