ᐅ How can I securely mount BILLY shelves on drywall?
Created on: 26 Dec 2023 19:43
Jokay
Jokay
26 Dec 2023 19:43
I am planning to install several IKEA BILLY bookshelves in my apartment, but the walls are mainly made of drywall panels (gypsum board). Since the shelves will be loaded quite heavily, I want to make sure that the mounting is truly stable and durable.
My question is: How can I securely fasten BILLY shelves to drywall? Are there specific anchors or brackets that work particularly well? Do I need to use special techniques to support the weight so the shelves won’t eventually come loose from the wall?
I’m looking forward to your tips and experiences! Thanks in advance.
juMira46
26 Dec 2023 20:37
Hey Jokay,
great question! Drywall isn’t exactly the most stable material when you want to hang heavy BILLY shelves. My first tip would be to use heavy-duty toggle anchors or cavity molly bolts. These open up behind the panel and distribute the load.
Jokay schrieb:
How do I securely attach BILLY shelves to drywall?
With these anchors, you can really mount the shelves safely without worrying about them eventually coming loose or breaking. And don’t forget: it’s best to fix the shelves to the wall in two, preferably three spots per shelf section – more distribution means less stress on the wall! 🙂
Good luck and have fun arranging your stuff! 😉
Laukau5
27 Dec 2023 08:14
Hello Jokay,
to answer your question thoroughly, I would first like to clarify that mounting BILLY shelves on drywall is indeed a challenge if they are to be fully loaded and remain permanently stable.
First, it is crucial to determine whether there is a supporting structure (wood or metal studs) behind the drywall. The best way to ensure stability is to attach the shelves directly to these load-bearing studs using appropriate screws, such as chipboard screws. The stud spacing is usually 60 cm (24 inches).
juMira46 schrieb:
My first tip would be: use heavy-duty ribbed anchors or so-called cavity molly bolts.
That is basically correct, but cavity anchors are better suited for medium loads since the drywall itself can’t bear too much weight. Therefore, they should not be the first choice for shelves carrying a total weight exceeding 20 kg (44 lbs) per fixing point.
My suggested procedure is as follows:
1. Use a deep scan device or magnet to locate a stud behind the drywall.
2. Screw the BILLY shelf rails or hangers precisely into these studs – this ensures the highest load capacity.
3. In areas without studs, you can additionally use cavity anchors to improve overall stability.
For maximum stability, you might also consider alternative wall fixings, such as shelving with floor supports or more robust shelving systems, especially if the wall is weak.
Also, keep in mind:
- Screws used should be at least 5 mm (0.2 inches) in diameter.
- Anchor length must be appropriate for the board thickness (cavity anchors for hollow walls).
- Load and load distribution per shelf should be planned in advance.
Can you tell me the size of the shelves and what you plan to store in them? Then I can provide more precise advice.
Nabla64
27 Dec 2023 15:03
Hello Jokay,
I’m happy to add a step-by-step guide on how to securely mount BILLY shelves on drywall.
1. Preparation:
First, use a stud finder to locate the metal or wooden studs behind the drywall. These provide the best support for weight.
2. Drilling holes:
Mark the drill holes on the shelf rails where you find the stud supports. This way, you avoid attaching the shelves only to the drywall itself.
3. Screws:
Use self-tapping metal screws (at least 4.5 x 50 mm (0.18 x 2 inches)) to ensure a firm hold in the studs. You can screw these directly into the metal studs.
4. Additional stabilization:
If you plan to install multiple shelves along a long wall, connect the shelves to each other using sturdy angle brackets or screw them additionally at the top and bottom directly into the stud frames.
5. Distribute the weight:
Spread the load over as many fastening points as possible. BILLY shelves are not designed for heavy loads, so consider placing particularly heavy items on other furniture.
Regarding cavity anchors:
Laukau5 schrieb:
That is basically correct, but these cavity anchors are better suited for medium loads.
Exactly—especially when storing many books or heavier items, these anchors are often not a long-term solution. If you don’t find studs, you can use so-called “heavy-duty drywall anchors.” These are somewhat more expensive but offer greater security than simple cavity anchors.
I hope this helps! Let us know what you’re planning and how we can best support you.
