ᐅ How can I securely install BILLY shelves on uneven tiled floors?
Created on: 23 Jun 2023 08:34
buferen
I am currently facing the following problem: I want to set up my IKEA Billy shelves on a rather uneven tiled floor in the living room. The issue is that the tiles are uneven in some areas, causing the shelves to feel unstable, wobble, and not stand straight. My specific question is: How can I secure or level my Billy shelves on such an uneven tiled floor so that they remain stable and upright over time, without the unevenness causing any damage to the furniture? I have already considered furniture glides or small shims, but I am unsure which solutions will be truly durable and also visually acceptable. I would appreciate any practical tips or experiences!
buferen
23 Jun 2023 11:27
sifope schrieb:
Have you checked whether the issue is caused more by unevenness in the tiles themselves or by the subfloor underneath?
I haven’t investigated that further yet; I was initially thinking more of a temporary fix at the shelf level, but rechecking the subfloor is a good suggestion.
Laukau5 schrieb:
Have you examined whether the tiles in that area already have cracks?
Apart from the unevenness, the tiles look fine visually—no visible cracks or anything like that.
What do you think about self-adhesive rubber leveling pads? Would they help, or are they more suited as protection rather than for leveling? Maybe combined with adjustable furniture glides?
gekira
23 Jun 2023 12:06
Regarding your question about self-adhesive rubber pads: these are mainly intended to protect the floor from scratches and only provide minimal compensation for uneven surfaces. They are not suitable for height differences of 5 mm (0.2 inches); they rather compensate for smaller irregularities of up to 1-2 mm (0.04-0.08 inches).
A durable and stable solution for your problem is to use adjustable furniture glides with fine threads. These allow precise adjustments.
A combination of adjustable feet plus a non-slip pad (such as anti-slip pads) can improve stability and prevent slipping.
In cases of larger unevenness, I would advise against purely self-adhesive solutions, as these can fail over time and cause the shelf to become unstable again.
If you are skilled in DIY, you can also attach small shims or spacer plates made of plexiglass or wood to the bottom of the shelf to compensate for unevenness and create a level base.
Friedrich
23 Jun 2023 12:44
First of all, respect for being so thoughtful about the stability. I also had Billy shelves standing on an old tiled floor with unevenness, and what helped the most was actually anchoring them to the wall, even though I had initially ruled that out.
The problem with uneven floors is often that the shelves start to tilt over time, which is not only inconvenient but also affects daily safety. The combination of adjustable feet and wall anchors worked perfectly for me, and although you can’t do that right now because of the glass front, maybe there’s a way to at least add some gentle support?
Otherwise: be patient. A mix of various small aids usually makes the difference. Minimizing wobbling by wedging, and preventing slipping with anti-slip pads.
All the best with your project, fingers crossed!
eldubi
23 Jun 2023 13:17
Buy adjustable furniture glides, set them to 5 mm (0.2 inches), and place non-slip rubber pads underneath. This will prevent any wobbling.
Charles
23 Jun 2023 15:02
In brief: For solid stability on uneven tile floors, I recommend using high-quality adjustable furniture feet with rubber soles. These compensate for small height differences and also protect the floor from scratches.
If the unevenness, as in this case, is up to 5mm (0.2 inches), it is essential to use furniture glides with a sufficiently long threaded stem to accurately level the difference.
I would not rely solely on self-adhesive pads or wooden wedges for long-term use, as these can shift or wear out over time.
sifope
23 Jun 2023 15:37
Charles schrieb:
For solid stability on uneven tiled floors, I recommend using high-quality adjustable furniture feet with rubber soles.
I agree with that. Just as a supplement: also make sure the threaded feet are not too stiff; otherwise, if you tighten them too much, the foot can get damaged or the shelf frame can become warped. A soft PU rubber on the foot is ideal.
gekira schrieb:
A combination of adjustable feet plus a non-slip underlay (such as anti-slip pads) can improve stability and prevent slipping.
That can also be important, especially if the shelving unit is not fixed to the wall. But you have to install it properly—the pads need to be positioned correctly; otherwise, the whole effort is wasted.
