ᐅ How can I securely and stably attach IKEA PLATSA back panels?
Created on: 6 Jun 2024 09:34
Pikristoff
I bought the Platsa wardrobe from IKEA and am currently working on attaching the back panels. My question is: How can I securely and stably fix the back panels of the Platsa so they don’t wobble or come loose over time? I have already used the supplied nails and plastic braces but notice that the back panel doesn’t fit perfectly in some areas, especially when I put some weight on the wardrobe.
Are there any tips or proven methods to further stabilize the back panels? Which tools or materials would be useful? I would appreciate practical advice, including explanations of why certain solutions work better than others.
Thank you in advance!
gasidney
7 Jun 2024 10:11
Attaching back panels:
- Drive nails in firmly
- Attach and screw in small battens inside
- Align the cabinet and secure it to the wall
This ensures a strong hold.
Lorukeo
7 Jun 2024 13:42
uslis47 schrieb:
A tight fit of the back panel can also be achieved by reinforcing it with small wooden battens.
This is a reasonable and technically correct suggestion. To add:
The use of wooden battens should be done in a way that avoids creating stress in the cabinet structure. The battens should not be too thick, so the back panel can still sit properly in the groove.
Additionally, applying acrylic sealant on the contact surfaces of the back panel can provide extra hold without reducing the possibility of later disassembly.
Securing the cabinet to the wall is preferable if it will actually bear load or could tip over, but for fastening the back panel alone, these measures offer a good balance between stability and simplicity.
likuken
8 Jun 2024 07:56
Pikristoff schrieb:
Are there any ways to make the back panel a bit tighter without directly screwing the entire cabinet to the wall?
That is a valid question. I still maintain: A back panel alone will never stabilize the cabinet as effectively as proper wall mounting. All "tightening" tricks are at best temporary solutions.
Lorukeo schrieb:
Wall attachment is preferable if the cabinet is actually loaded or could tip over
Exactly. IKEA also generally recommends securing Platsa units to the wall in the assembly instructions. When it comes to safety and stability, that is simply the best advice and cannot be ignored.
If someone says wall mounting is not necessary, they are underestimating the structural forces and the risk of potentially dangerous tipping moments.
