ᐅ How can I securely install IKEA Metod cabinets in rental apartments without causing damage?
Created on: 23 Aug 2023 09:37
Neopau
Neopau
23 Aug 2023 09:37
I am currently outfitting my kitchen in my rental apartment with IKEA Metod cabinets. I want to make the installation as secure as possible so that the cabinets are firmly fixed to the wall and cannot tip over. At the same time, it is very important to me that I can remove the cabinets later without leaving any damage or marks on the walls.
My questions are:
- What installation methods do you recommend to securely anchor the cabinets?
- Are there special anchors or fastening systems that work particularly well for rental apartments?
- How can I avoid holes or unsightly marks on the walls when removing the cabinets?
- Do you have any tips for preparing the walls or protecting them to minimize traces when taking the cabinets down?
I have read that some people avoid screws and instead use Velcro, special hooks, or magnetic systems, but I couldn’t find reliable information on this.
I look forward to your experiences and advice, as I want to start this project soon and am unsure how to implement it in a durable and rental-friendly way.
Thanks in advance!
Mufato
23 Aug 2023 11:16
for safety reasons, I recommend mounting IKEA Metod cabinets using suitable anchors that are matched to the wall type (e.g., heavy-duty anchors for concrete). In rental properties, cavity anchors are best for drywall.
For a residue-free installation, you can use special adhesive hooks or mounting tapes, but these are not as load-bearing.
Holes can be easily filled with appropriate filler after removing the screws.
LOGEMIN
24 Aug 2023 08:42
Hello Neopau,
I want to give you a brief step-by-step guide on how to safely install your IKEA Metod cabinets and minimize leftover marks afterwards:
1. Determine the wall type precisely: Use heavy-duty anchors for concrete or brick walls, and cavity anchors for drywall. Screws and anchors must be appropriate for the weight of the cabinets.
2. Securely connect the Metod cabinets: Use the supplied connecting screws between the cabinets to create a stable unit.
3. Wall fastening: IKEA wall brackets are strong and secure. To avoid damage, use small drill holes preferably in the joints (for brick) or with minimal effort.
4. Residue-free removal: Use filler for the holes; work cleanly and sand after drying. Small drill holes usually aren’t a big issue in rental apartments, but make sure to work carefully and neatly.
5. Alternative methods: If you want to avoid drilling holes altogether, strong hook-and-loop or magnetic solutions usually aren’t strong enough. The safety of your kitchen is more important!
Conclusion: Secure installation always means making small interventions in the wall. If you carry out the installation professionally and properly close the holes afterwards, you will have no problems during handover.
If you have questions about specific anchors or tools, feel free to ask.
labar43
24 Aug 2023 14:53
LOGEMIN schrieb:
Alternative methods: If you really want to avoid drilling holes, reliable hook-and-loop fasteners and magnetic solutions are usually not strong enough. The safety of your kitchen is more important!
I completely agree! 😊 Screwing into the wall is a bit of extra effort, but it will make your kitchen completely secure!
At first, I was hesitant too, but then I dared to drill properly and filled the holes with filler. It worked great, and the landlord didn’t say anything.
So be brave, do it properly, and you’ll enjoy your Metod cabinets for a long time! 😄
nubar
25 Aug 2023 10:28
To ensure a clean and safe installation, I recommend the following:
- Thoroughly inspect the wall before installation. Uneven surfaces or weak spots can cause problems.
- Use high-quality anchors that are suitable for the wall material.
- Use a spirit level to install the cabinets precisely; this prevents stress and loosening over time.
- If you need to fill holes, use an appropriate fine filler and sand carefully afterwards.
All of this helps to minimize damage and makes the return of the rental property hassle-free.
For rental apartments, a clean and professional installation combined with proper finishing work is essential to avoid conflicts.
