ᐅ How can I securely and easily install Ikea Brimnes shelves?
Created on: 18 Nov 2024 08:23
Lauoscar
Lauoscar
18 Nov 2024 08:23
Good morning everyone,
I am about to install the new Ikea Brimnes shelves and want to do it as safely and easily as possible.
My question: What process and tools would you recommend to ensure the shelves are really stable, especially since I plan to load them with books and other heavy items in the future?
I have already read the instructions, but I find them somewhat brief regarding fastening details – for example, how to best insert the dowels into the pre-drilled holes, how to choose the correct screw size, and if there is any particular detail about the Brimnes that should be considered to avoid wobbling or sagging.
I would appreciate any tips, especially advice that goes beyond the basic assembly guide and is based on practical experience.
Domau0
18 Nov 2024 10:37
Hello Lauoscar,
First of all, I find your request very clearly described – this really helps to address it precisely.
Regarding your question about how to safely and easily install the Ikea Brimnes shelves, I would like to provide you with a detailed step-by-step guide based on my experience and common pitfalls:
- Tools: For the assembly, I recommend having a cordless drill with torque control (around 8–10 Nm), a small hammer, and good flathead and Phillips screwdrivers ready.
- Inserting the dowels: The pre-drilled holes conform to standards and fit the supplied plastic dowels. It is important to insert the dowels straight and without excessive force. Some tend to hammer them in too deep – you should avoid this because then they won’t provide optimal holding strength in the drilled hole walls.
- Screw selection: Ikea supplies suitable screws that you can generally use as provided. If you want extra stability, you can opt for longer screws of the same thickness (usually 4 mm, lengths between 30 and 40 mm) – but not too long, as that could cause the screws to push through.
- Shelf installation: Position the shelf supports (small metal or plastic brackets) exactly into the designated holes, align the shelves, and carefully screw them in. Be careful not to tighten the screws too much to avoid damaging the material.
- Especially with Brimnes: This series features relatively thin panel construction, so I recommend not loading the shelves with extremely heavy items. The maximum static load per shelf is about 15 kg (33 lbs). If you plan to place heavier objects, distribute the weight or consider additional support measures.
One last question: Are you working alone, or can you ask someone to assist you in adjusting the shelves? This makes alignment much easier.
I hope this helps you get started. If you like, I can also provide some technical tips on alignment and further securing.
nubar
19 Nov 2024 14:56
This is a very important point, which I can confirm. Additionally, I can say that especially with Brimnes, the material is quite soft and prone to over-tightening the screws. Therefore, I recommend setting the screws carefully with a torque limiter, as already mentioned.
Another tip: Before final tightening, check whether all holes are clean. In some of my Brimnes furniture, wood chips had collected inside the drilled holes, making dowel insertion difficult. You can carefully clean the holes with a small wooden stick or similar tool. This ensures the dowels and screws fit securely and prevent wobbling.
I have also had good experiences when slightly tilting the shelves from underneath while they rest on the supports, to make sure the support contacts the shelf at multiple points. This results in a significantly better load distribution.
If you want maximum stability, you can also consider using clamps during assembly to hold everything precisely in place before tightening the screws.
Jensson
20 Nov 2024 09:12
Good morning,
I would like to share my experience for a secure and easy installation of the Ikea Brimnes shelves in a short but structured guide:
- Preparation: Check all parts for completeness and consult the assembly instructions again. Ikea parts often come with pre-drilled holes, but these are not always cleanly made.
- Correct dowel insertion: As mentioned, insert dowels without excessive force. If needed, use a rubber mallet gently to tap the dowels into place.
- Adjusting screws: Never fully tighten screws before all are positioned – this makes fine adjustments easier.
- Load capacity: The maximum load capacity of shelving made from thin particleboard is usually around 15 kg (33 lbs) per shelf. Heavier books should be distributed across multiple shelves.
- Additional stabilization: If you attach the shelf unit to the wall (which Ikea also recommends), ensure the brackets are firmly secured and use the appropriate corner brackets provided.
Regarding a common mistake: simply resting the shelves loosely on the supports and tightening the screws too much can cause warping or make the entire structure unstable. It’s better to proceed step by step and check repeatedly.
One tip missing from the instructions is the correct order for screwing in – start with the lower dowels and screws, then work upwards, which improves precision.
I’m happy to help if you have any questions.
