Hello everyone, I am preparing for a move and have several BILLY shelves from IKEA that I want to transport safely. My question is: How can I secure BILLY shelves during moving and transport to prevent damage and maintain their stability? Specifically, I am interested in how to handle shelves that are partially or fully assembled, which techniques and materials work best, and if there are any special tips to reduce the risk of damage, such as to the shelves or the back panel. It would also be helpful to know whether it’s better to disassemble the shelves or keep them fully assembled to save time without compromising stability. If anyone has experience with safely securing or transporting IKEA BILLY shelves and can offer practical advice, thanks in advance!
Pura1 schrieb:
How do I secure BILLY shelves during moving and transport to prevent damage or instability?It's great that you brought up this topic here! 🙂 In my experience, it's definitely worth fully disassembling the shelves and carefully packing all parts. Wrap the shelves individually in bubble wrap or blankets to avoid scratches, and only bend the back panel gently when removing it. If that’s too time-consuming, you can also wrap the fully assembled shelf several times with stretch wrap to create a firm protective layer and prevent shifting. And very important: During transport, do not lay the shelves flat; ideally, secure them in an upright position! It’s amazing how stable the BILLY shelves remain with this method!
bauku schrieb:
Wrap each shelf individually in bubble wrap or blankets to prevent scratchesAdditionally, I recommend a systematic approach: First, remove all shelves and small parts. The back panel of the BILLY bookshelf is usually made of a very thin hardboard, which is fragile. Either carefully remove it and transport it separately or, if possible, do not disassemble it at all—but then make sure it is well padded.
Once all individual parts are securely packed, you should mechanically stabilize the main carcass— for example, by reinforcing the back panel from the inside with strips of wood or metal clamps. This prevents the shelves from shifting during transport. Even moderate shocks can dislodge the cam connectors or dowels, so applying securing tape on critical internal joints is helpful.
The idea of always storing shelves vertically is absolutely correct. Laying them flat can cause warping or damage from the weight of stacked components.
I am also curious: Have you ever transported the shelves fully assembled before, or is this your first move? This can affect the effort required to secure them.
Pura1 schrieb:
whether it is advisable to disassemble shelving units or keep them fully assembledIn general, disassembly increases transport safety because the individual parts are lighter, take up less space, and are easier to protect. However, reassembly requires time and effort.
For BILLY shelves: The connecting elements (dowels, screws, back panel nails) are not designed for frequent disassembly and reassembly. Therefore, I recommend at least partially disassembling the shelves – at minimum, remove the shelves and back panel.
The back panel is fragile and can break easily; without it, the carcass loses structural stability, but for transport this can be beneficial as it prevents the unit from twisting.
If you want to transport the shelves fully assembled, secure all movable parts inside with tape and wrap them tightly with appropriate protective film to prevent shifting. Avoid stacking, keep them upright, and use ratchet straps or tie-down straps if possible.
In summary: Disassembly combined with careful packaging is safer, but if time is limited, you can manage with fastenings and protective film on assembled units. Always consider the transport route – uneven roads require additional protective measures.
