ᐅ How can I seal in chemical odors from the KALLAX?
Created on: 9 Dec 2020 08:37
deoso
deoso
9 Dec 2020 08:37
I have a KALLAX shelving unit from IKEA in my office where I store some chemical substances. Occasionally, a very unpleasant chemical odor escapes, which is not effectively contained by the simple open shelves. I would like to know the best way to seal or isolate the chemical odor from the KALLAX unit without damaging or significantly altering the furniture. Are there any proven methods or practical tips to effectively stop the odor leak? I am especially interested in which materials or seals are suitable and whether air circulation should be considered to prevent odor problems. I would appreciate concrete suggestions, ideally with advice on how to implement them.
Thanks in advance for your help!
Danabla
9 Dec 2020 09:26
To effectively seal in the chemical odor, it is advisable to first take a comprehensive look at all possible points of release. The KALLAX shelving unit is basically open in design, so adding doors or shelf inserts as extra barriers makes sense.
1. Doors: There are overlay or inset fronts that can be mounted onto the compartments. These should be equipped with seals along the edges to achieve the most airtight closure possible.
2. Sealing materials: For this purpose, self-adhesive silicone seals or rubber sealing strips are suitable to reliably seal the joints.
3. Additional air barriers: A foil or a thin barrier board can be attached to the inside to prevent odor molecules from escaping.
It is also important to monitor the storage temperature and air circulation inside the shelving unit, as higher temperatures increase the volatility of the chemicals.
Overall, I would recommend either retrofitting doors with seals or making individual compartments airtight with additional covers.
Layla
9 Dec 2020 10:13
I can well understand how unpleasant this smell must be, especially when you spend a lot of time in the office! I have personally experienced how difficult it is to get rid of chemical odors, particularly when the piece of furniture is not designed for it.
In addition to Danablas’s suggestion, I would recommend considering storing the chemicals in airtight containers. That made the biggest difference for me, as the self-adhesive seals alone only partially solved the problem.
It might also help to use an air purifier with an activated carbon filter to improve the indoor air quality, in case full sealing is not possible.
Keep at it—I hope you find a good solution soon, because such a smell can really be stressful.
BOSULE
9 Dec 2020 13:57
This is an important point. Additionally, I recommend paying particular attention to the compatibility of seals with the surfaces when installing them to ensure long-lasting adhesion.
It is also important to check which chemicals will be stored, as some solvents can damage sealing materials. Silicone-based seals are generally more resistant than rubber, which tends to become porous over time.
Furthermore, it should be noted that an overly airtight seal can promote the buildup of pressure or gases with certain chemicals, which could be hazardous. In such cases, slight ventilation or filtration may be advisable.
sihau
9 Dec 2020 15:22
To add to the previous comments:
A proven method is to use self-adhesive foam rubber seals on all contact surfaces to ensure the cabinet doors close as tightly as possible. These seals are easy to apply and elastic enough to compensate for minor unevenness.
Additionally, care should be taken to avoid gaps that odors could pass through, for example at the junction between the shelf compartment and the door frame. Silicone or acrylic sealants can also be used in these areas.
If complete sealing is not achievable, activated carbon air filters installed in the room can be considered to drastically reduce odor concentration.
deoso
10 Dec 2020 07:54
Thank you very much in advance for the helpful tips!
@BOSULE: The information about different chemicals and the durability of sealing materials sounds very important. I mainly store solvents like acetone and ethanol, but also smaller amounts of nitromethane. I will definitely go with silicone since it seems more resistant to chemicals.
Also, I am wondering if it makes sense for sealing purposes to reinforce the back panel of the shelf or even attach a membrane behind it to create a kind of barrier layer?
And @Layla: Airtight containers are indeed a good idea – so far, I have been using plastic bottles with screw caps, but they are not completely odor-tight. Can anyone recommend sturdy alternatives?
