ᐅ How can I safely transport Billy bookcases over long distances?
Created on: 15 Nov 2024 08:37
nauneoHello everyone,
I am planning a move soon, during which I need to transport several IKEA Billy bookcases safely and without damage over a long distance. My question is quite specific: How can I transport Billy bookcases securely over long distances so that neither the paint nor the glued joints get damaged, and the bookcases can be reassembled afterward with minimal effort?
I have already considered disassembling them, but I’m concerned about the fixed back panels – these cannot be easily removed and keep the unit completely stable, but also make it heavier and bulkier. I’m also wondering whether it is better to protect the top panels, shelves, or side panels by transporting them individually or assembled within the unit.
I would appreciate any tips on packaging, handling during loading and unloading, and possible tools or aids. Many thanks in advance for your ideas and experience!
Hi,
It’s best to disassemble the shelves as much as possible. Wrap the individual parts separately in bubble wrap or blankets. You can transport the back panels at an angle or place them between the other parts. Make sure everything is well padded to prevent rubbing against each other.
This way, you can avoid scratches and damage.
neoren schrieb:
It’s best to disassemble the shelves as much as possible.Absolutely, that’s really the best advice! 🙂
I always add a layer of blankets or towels around them because the plastic sheeting alone sometimes isn’t enough, especially if the shelf is stored for a longer period. Then I put light boxes or maybe some foam pieces in between – those make a big difference.
Don’t forget to label everything so you don’t get frustrated when reassembling – speaking from experience 😅.
Good luck with the move!
Hello nauneo,
Your question is very practical and well formulated, thank you for that. For the safe transport of Billy shelves over long distances, I recommend the following procedure:
1. Disassembly: It is best to completely take the shelves apart. The back panels are usually made of thin hardboard or MDF panels, which provide stability due to their position. Without the back panel, the shelf can become unstable, but for transport, it is unavoidable to store them separately.
2. Protection of individual parts: Each panel should be individually padded – bubble wrap or thick moving blankets are ideal choices here. It is especially important to protect the edges and corners, as these are easily damaged during transport.
3. Back panels: It is best to place these upright between the other shelf parts or secure them with ratchet straps, which provide stability without damaging the material.
4. Loading: When loading, make sure nothing shifts – the vehicle should have a flat loading surface and, if possible, tie-down points. I recommend using ratchet straps to securely fix everything in place.
5. Screws/fasteners: Pack all small materials neatly and label them well. This way, you can quickly find the correct parts when reassembling.
One more question: How long is the distance and what type of vehicle will you be using? This can influence the recommended protective measures.
I hope this helps you!
Domau0 schrieb:
It’s best to fully disassemble the shelves.I agree and would like to add that handling the back panels is crucial. Since they can often break or tear out, you should avoid bending or applying too much pressure on them.
I usually rely on a combination of soft blankets and a tightly secured transport strap to prevent them from sliding around too much. It’s also a good idea to protect the inner surfaces with a thin, clean separator paper or a light cardboard before placing the top panel on.
In terms of the vehicle, it’s best to load the cargo space as evenly as possible to avoid shocks on individual parts.
If you use transport aids, such as furniture dollies, handling can be safer and gentler.
warrenka5716 Nov 2024 16:58nauneo schrieb:
How can I safely transport Billy bookcases over long distances, so that neither the finish nor the glued joints get damaged, and the shelves can be reassembled with minimal effort?I totally understand – I had the same concerns before my last move. With my Billy bookcases, I focused on being very careful and driving more slowly because vibrations put a lot of stress on the wood.
It’s also important to keep track of the individual parts – I made a diagram and took photos when I took the shelves apart, then simply followed that step by step when reassembling.
If you’re still unsure whether it’s worth taking them apart, keep in mind that the back panels can easily tear, especially if the shelves are older. It’s better to spend a bit more time and use padding from the start.
I hope this helps give you some confidence. 🙂
