ᐅ How can I securely install Ikea Metod wall cabinets on drywall/plasterboard walls?
Created on: 25 May 2021 09:37
Batugau
Batugau
25 May 2021 09:37
I am planning to install the IKEA Metod wall cabinets at home on drywall, but I have concerns about how to do this safely and, above all, securely in terms of load-bearing capacity. Since I know that drywall is not as stable a base as a solid wall, the question arises which specific fasteners and installation methods are appropriate for mounting the Metod cabinets to ensure both safe load support and a durable solution.
Specifically, I am interested in the following points:
- Which anchors or fasteners are best suited for the weight of the Metod wall cabinets on drywall?
- Should you drill directly into the drywall or rather behind the drywall into the underlying structure (e.g., metal studs or wooden beams)?
- How can I reliably locate the underlying structure or support studs, if present?
- Are there any special tips or experience on mounting the cabinets securely and without any wobbling?
I look forward to your experiences and advice on how to best approach this quite challenging project, as safety and proper installation of the cabinets are very important to me.
Thank you in advance!
Scarlett
25 May 2021 11:52
Batugau schrieb:
Specifically, I’m interested in the following points:
- Which anchors or fasteners are best suited for the loads of Metod wall cabinets on drywall?
Hello! I totally understand your concern; it definitely makes sense to be cautious with drywall. I once tried to install Metod wall cabinets on drywall myself, and honestly, it was quite stressful at first.
My key takeaway: If you screw only into the drywall board, you can quickly run into problems because the weight of the cabinets is simply too heavy. It’s better to always locate the load-bearing studs (usually metal profiles) behind and fasten the cabinets there.
Batugau schrieb:
- How can I reliably find the substructure or support studs, if present?
To find the studs, I recommend using a good metal or wiring detector. I initially had good results with a basic electronic detector. It’s important to check early before drilling any holes, as the load-bearing studs are key to a secure hold.
If there are no studs at the desired location, adding a wooden board as a mounting base can be a solution. You can screw this board to the studs below and then fix the cabinet onto it.
I know this might sound a bit fiddly, but it’s really worth the effort because even small mistakes can lead to an insecure wall mounting over time.
Good luck, and feel free to ask again if you need more detailed help with any of the steps!
reni45
25 May 2021 13:06
It is best to attach directly to the metal or wooden studs behind the drywall, otherwise the anchors will not hold securely.
Be sure to use metal expansion anchors or toggle bolts, as they are more stable than standard drywall anchors.
First, locate the supporting structures using a stud finder and measure them.
Juan31
26 May 2021 08:19
The safest way to install IKEA Metod wall cabinets on drywall (gypsum board) is by following these steps:
- Locate the load-bearing substructure: Drywall is usually mounted on a framework of metal studs or wooden battens. A reliable cable detector with metal detection can help identify the position of these vertical studs.
- Use appropriate fasteners: There are special heavy-duty anchors for drywall (e.g., metal toggle bolts or butterfly anchors). However, these are only secure if they properly engage the cavity structure behind the drywall. If a stud is directly behind the drilled hole, screwing directly into the stud provides the most stable support.
- Alternative method if no studs are available: Adding a layer of wood panels (at least 18 mm (0.7 inches) thick) onto the drywall, screwed directly into the studs, can better distribute the load. The cabinets are then fastened to the wood panel.
- Consider the load: A Metod wall cabinet loaded can quickly weigh 20–30 kg (44–66 lbs). Multiple cabinets side by side increase the overall load. Attachment points must be able to support this weight safely.
- Follow IKEA’s installation instructions: These generally recommend fixing cabinets to solid walls or studs and explicitly warn against relying solely on drywall for support.
In summary: Screw into the load-bearing substructure, use reinforcement panels if needed, and choose suitable anchors. This ensures secure and long-lasting stability.
Marlenepa
26 May 2021 15:44
Juan31 schrieb:
There are special heavy-duty anchors for drywall (e.g., metal toggle anchors or toggle bolts).
That is absolutely correct, and I would like to add: these anchors are specifically designed for drywall to hold loads when screwing into hollow spaces. However, it is crucial to always observe the maximum load capacity of each anchor.
Juan31 schrieb:
If there is a stud directly behind the drilling spot, screwing a screw directly into the stud is the most stable option.
Exactly, you should always try to secure the screw with an anchor into the metal stud, as this is the most solid solution.
If you cannot precisely hit the studs, I recommend the following approach:
- Get a sufficiently large wooden board (e.g., plywood)
- First, mount this wooden board at several points onto the studs
- Then mount the Metod wall cabinets onto this wooden board
This way, you distribute the load very well and avoid damage to the drywall.
As a final tip: take your time planning the mounting distances and carefully check the height so you don’t have to drill again later. Mounting IKEA cabinets on drywall requires some patience and precision, but it’s definitely worth it!
