ᐅ How can I replace IKEA Metod screws in damaged holes?
Created on: 28 Oct 2017 09:47
ruzar
ruzar
28 Oct 2017 09:47
I am currently working on repairing my IKEA Metod kitchen cabinet fronts, but I have encountered a problem: some of the screw holes for the Metod fittings are damaged or worn out, so the original screws no longer hold securely. I would specifically like to ask how to best replace the IKEA Metod screws or their function when the holes have become enlarged and stability is compromised.
I understand that simply using replacement screws alone will not solve the issue, so I am open to solutions such as special wall plugs/dowels, filler materials, or mechanical alternatives to reliably fasten the damaged wood again.
What has worked well for you in such cases? Are there IKEA-specific replacement parts available, or do you need to use generic products? Experiences with repair kits or technical tricks are also very welcome.
Thank you in advance for your advice!
minjan
28 Oct 2017 10:03
If the screw holes are worn out, wooden dowels or so-called wood repair fillers often help.
- Blow out the hole
- Fill with wood filler and let it cure
- Pre-drill again and screw in the screw
Alternatively, you can also use larger screws if the material allows.
SUBEN60
28 Oct 2017 11:18
The issue with damaged screw holes in IKEA Metod kitchens often relates to the particle board used, which can expand or contract over time. For a professional repair, I recommend the following procedure:
- Remove the old screw and clean out the damaged hole
- Fill the hole with a wood-repair epoxy filler specifically designed for wood; this provides good load-bearing capacity
- After the epoxy has fully cured, pre-drill a new pilot hole with a wood drill bit
- Insert a new screw, ideally with the same diameter or slightly larger
Alternatively, I have had good results with so-called threaded insert screw systems, which offer greater hold if you can access the back side.
Since IKEA does not provide special replacement screws for damaged holes, using generic solutions available at hardware stores is the most practical approach. It is important that the screw not only fits tightly but also withstands lateral forces, especially on kitchen cabinet fronts.
Josan
29 Oct 2017 13:32
Hello ruzar,
your question is very well posed and the topic concerns many people who have IKEA Metod kitchens. Damaged screw holes are frustrating because the furniture is designed for fittings to fit precisely.
First of all: As long as the hole is not completely torn out, you can often repair it with wood filler or special repair kits for chipboard and plastics. These fill the hole and create a new stable surface. It is important afterwards that the screw does not sit too loosely. For this, it makes sense to screw into a newly drilled hole rather than the old one after the filler has dried.
If you cannot insert a larger screw or a dowel from the back of the panels, you can also use so-called barrel nuts or threaded inserts. These significantly improve the hold. I have installed such fittings multiple times in IKEA kitchens;
SUBEN60 schrieb:
Alternatively, I have had good experiences with so-called cap nut screw systems that provide a more secure hold if you can access the backside.
That also matches my experience. Sometimes it is also worth using wooden dowels pressed into the damaged hole – for example, solid round wood glued in place and later used as a new screw hole.
If you are asking about the original IKEA Metod screws: replacements are officially available, but the screws themselves are quite standardized. The challenge lies more in having an intact screw hole than in the screw itself.
If you can provide more details about the exact damage to the holes, I can gladly give you more specific advice.
