ᐅ How do I replace damaged MALM dresser side panels?
Created on: 15 Jul 2015 08:23
TARVIN
TARVIN
15 Jul 2015 08:23
Good morning everyone, I’m facing an issue with my MALM chest of drawers from IKEA. Unfortunately, some of the side panels are damaged – the right side panel is cracked, and on the left side, there is an area where the surface has chipped off. Since I want to continue using the piece of furniture, I’m considering how to properly replace the damaged side panels.
My question to you is: What is the best way to replace the side panels of the MALM chest of drawers without disassembling the entire unit? Which tools and replacement parts are needed, and are there any specific steps to keep in mind to maintain both stability and appearance?
I look forward to your tips and experiences.
O
olivernu
15 Jul 2015 09:12
Hello TARVIN,
with MALM dressers, the side panel is usually attached to the bottom and top panels using dowels and screws. To replace it, you need to remove the drawers first and then loosen the fasteners on the corresponding side. A cordless screwdriver with the appropriate bit is very helpful for this.
Important: When removing the parts, be careful not to damage any other components. For replacement parts, it’s best to contact IKEA directly or a dealer that supplies furniture spare parts.
I also recommend counting all screws carefully and noting their positions before disassembly. This way, you can reassemble everything precisely. Good luck!
blaje2
15 Jul 2015 09:45
You need to remove all the drawers first. Then, remove the screws on the side. Take off the old side panel and attach the new one. Tighten the screws. Done.
mifusau
15 Jul 2015 11:28
Hello TARVIN,
I would like to suggest a brief procedure for replacing the side panels of the MALM chest of drawers to avoid common mistakes:
1. Preparation: Remove all drawers and shelves.
2. Detaching the side panels: Usually, the side panels are secured to the bottom and top panels with several screws from the inside. Loosen these screws using a suitable Phillips screwdriver or power drill.
3. Caution during disassembly: Since the side panels often serve as load-bearing elements, keep the chest stable while loosening the screws (e.g., have a second person hold it or lean it against a wall).
4. Replacement parts: It’s best to buy matching side panels directly from IKEA or from furniture spare part stores. Make sure that the dimensions, drill holes, and surface finish match.
5. Assembly: Attach the new side panels with the same screws, check their fit, and remove any dirt or adhesive residue from the old surface.
6. Completion: Reinstall the drawers and shelves.
A typical mistake is putting excessive stress on the side panels while they are being replaced. Therefore, take your time and proceed step by step.
I hope this overview helps you!
TARVIN
15 Jul 2015 12:15
olivernu schrieb:
It’s best to contact IKEA directly or a retailer who sells furniture spare parts.
Thank you very much for the tip!
I had feared that I wouldn’t be able to get new side panels as individual parts – that makes things a lot easier.
mifusau schrieb:
A common mistake is putting too much stress on the side panels while the replacement is still in progress.
I didn’t know that; it’s an important tip for stability during the work.
I have one more question: Do I need to completely remove the screws from the side panels, or is it enough to loosen them slightly in order to separate the panel? Could there be clips or other fasteners that I might have overlooked?
O
olivernu
15 Jul 2015 13:47
It is advisable to completely remove the screws, as the side panels usually do not have additional clips. This is the only way to fully detach the side panel without damaging other parts.
Be careful with the dowels, which are sometimes located in the front or back of the carcass; these usually remain embedded in the panel. If they are damaged, you should replace them with new ones, as they are important for stability.
