ᐅ How do I repair cracked fiberboard bed side panels?
Created on: 30 Aug 2021 09:23
ELVEDINNA
ELVEDINNA
30 Aug 2021 09:23
Hello everyone, I need your expertise: What is the best way to repair cracked wooden or particleboard bed side panels from a Malm bed? I noticed that the side panel on my IKEA Malm bed is cracked near the bottom, probably due to constant stress or an impact. The surface is painted, and I would like to carry out the repair in a way that maintains stability and makes the repair as invisible as possible. Which materials, adhesives, or maybe wood filler do you recommend, and what is the exact procedure to reglue or reinforce the bed sides? I am fairly handy, but I lack a clear plan and would also appreciate tips for the finish. Thanks in advance for your ideas and suggestions!
Lisele
30 Aug 2021 10:07
ELVEDINNA schrieb:
How can I best repair cracked wooden or particleboard Malm bed sides?
I know this problem well—I have the same kind of bed myself. The crack is really frustrating, so first of all, respect for taking it on! I used an epoxy adhesive back then, which holds extremely well. It was important for me to clean the area thoroughly first and carefully remove any loose parts. Then I clamped the glued area with small clamps to ensure the adhesive cured properly.
The hardest part for me was reinforcing the crack. I attached small wooden strips on the inside and glued them together to add extra stability. Maybe you could try that too?
I know the surface won’t look perfect afterward, but using fine sandpaper and a suitable paint or finish from the hardware store helped me blend it in quite well visually. Maybe you’d like to share how you proceed—it could motivate others here. 🙂
anken
30 Aug 2021 11:56
Basically, I would recommend first thoroughly cleaning the crack and then gluing it with a high-quality white glue (PVAC), which is very suitable for wood and veneer work. Epoxy resin is extremely strong but can be difficult to repaint or sand later on.
If the crack is already quite large or the panel becomes unstable, the backside should be reinforced with a thin wooden strip (e.g., spruce, 20x12 mm (0.8x0.5 inches)). This strip is glued (preferably with wood glue) and clamped with screw clamps until everything is dry.
After drying, the surface should be gently smoothed with fine sandpaper (grit 180 to 220). For the appearance, a thin coat of varnish or wood finish that matches the original is recommended.
V
vinpau
30 Aug 2021 14:39
Lisele schrieb:
I used an epoxy adhesive back then, and it holds really solidly.
That’s brilliant! 🙂 Epoxy adhesive really does make a difference—I hadn’t even considered it.
I once did a small repair on a similar bed using wood glue—it worked, but the bond strength wasn’t as good as I had hoped.
My tip: after gluing, place something heavy on the repaired area and be patient! Also, make sure to thoroughly clean the surface beforehand, as that improves the adhesive bond.
Looking forward to seeing how it goes for you—that kind of feedback is always encouraging! 🙂
KAMERON
30 Aug 2021 17:15
In addition to the previous recommendations: When repairing particleboard, it is important to note that cracks are often caused by the tearing out of wood fibers, which limits the effectiveness of the adhesive. To achieve a durable and stable result, it is advisable to smooth the edges with a fine chisel or sandpaper before gluing, so the adhesive can better wet the surface.
For bonding, wood glues with high water resistance (e.g., D3 or D4 classified adhesives) are suitable and are commonly used in furniture making.
Reinforcing by gluing on battens is useful; however, care should be taken that the battens are not too thick or heavy, as this could increase stress at the repaired area again.
TANBLA
31 Aug 2021 08:21
KAMERON schrieb:
Adhesives especially suitable are wood glues with high water resistance\
Wood glue (D3/D4) is my favorite.
Smooth the edges beforehand and fill cracks with glue.
Clamp until dry. Nothing more.
