Hello everyone, I have noticed that some edges of the frame on my Malm bed have developed cracks and chipping. These look unattractive, and I am concerned that the damage might worsen over time.
I am interested in learning how to best repair these cracked edges myself, without having to disassemble the bed or order entirely new parts.
Are there specific adhesives, fillers, or treatments that work especially well on the surface of MALM beds made from particleboard or laminate?
I would appreciate any advice, material recommendations, or practical experiences you can share!
zarlu schrieb:
Or is it sometimes better to replace damaged parts?From a technical perspective, replacement is always the ideal solution because it best preserves stability and appearance. However, in practice, this is often costly and labor-intensive, especially for minor damage.
A high-quality repair, as described, can sufficiently maintain the lifespan and appearance of the frame if there are no critical structural damages.
Thanks to everyone for the valuable tips and discussions!
Here is a brief summary of my findings:
- Cleaning and lightly sanding the damaged laminate edge
- Using a single-component plastic filler suitable for laminate
- Sanding with very fine grit paper to achieve a smooth surface
- Sealing with laminate adhesive or clear varnish, with possible touch-up using paint
If I follow these steps, I should be able to achieve a visually appealing and durable repair.
I will report back on how it went.
