ᐅ How do I repair the Malm bed frame after a fall?
Created on: 20 Jan 2023 08:23
tolupu
Hello everyone, I have a problem with my Malm bed frame, which unfortunately got damaged after a fall. Specifically, the lower frame that supports the mattress has cracked on one side and is no longer stable. The fall height was about 40 cm (16 inches), the frame is made of pine wood, unreinforced, and I suspect that the supporting crossbeam is broken or at least severely weakened. Now I am wondering how to best approach this repair without having to replace the entire frame. What tools and materials do I need for this, and is there a proven method to restore the stability? I would appreciate any advice that helps me make the bed safe and stable again!
tyson51
20 Jan 2023 12:35
tolupu schrieb:
How many dowels for about a 30 cm crack?
For a length of 30 cm (12 inches), I recommend 4 to 5 dowels, spaced about 5–7 cm (2–3 inches) apart.
tolupu schrieb:
Drill bit size
The dowel should fit tightly. Usually, 6 or 8 mm (1/4 or 5/16 inch) dowels work well with pine wood. The holes must be drilled precisely, ideally using a dowel drill bit.
tolupu schrieb:
Staggered drilling?
Yes, it’s best to drill staggered, not directly opposite each other, so the crack is properly compressed. This way, the joint can handle load better. Then clamp everything firmly with clamp screws and allow the glue time to cure.
retau
20 Jan 2023 13:04
It’s great that so much expertise comes together here! 🙂 When drilling holes for wall plugs, stagger the holes slightly and use glue sparingly to prevent swelling. Make sure to guide the drill bit perfectly straight so the plugs fit precisely. After drying, you’ll have effectively given your bed frame a new lease on life! 🙂
Ethan
21 Jan 2023 07:55
Hello tolupu, I would like to add that with older or stressed pine wood, it is better to also screw a thin metal plate under the break point. Make sure to pre-drill small holes for the screws before fastening to avoid further splitting the wood. This increases stability and prevents the frame from giving way again soon.
JAFUHAU
21 Jan 2023 08:41
I can easily understand how frustrating damage to a bed can be – especially if you don’t want to replace everything right away. The suggestions involving anchors, glue, and possibly metal brackets sound very solid. Would you feel confident tackling the repair yourself, or would you prefer to take it to a workshop or carpenter? Sometimes it helps to discuss the assembly first before getting started. 🙂
tolupu
21 Jan 2023 09:12
JAFUHAU schrieb:
Would you dare to tackle the repair yourself?
Yes, I definitely want to try it myself. The tips here make the process clearer. I have the tools and wood glue at home, I just need to get the dowels and possibly some metal brackets. Thank you for patiently helping me with your helpful advice!
