ᐅ How do I fix squeaking Malm furniture?
Created on: 21 Aug 2017 08:16
X
Xenoge
X
Xenoge
21 Aug 2017 08:16
I have recently started using some Ikea Malm furniture (bed frame and desk), and unfortunately, they have begun to squeak increasingly. I have noticed that the squeaking mainly occurs under load or movement at the connection points (screws and joints).
I would like to know the most effective way to fix this without having to disassemble all the furniture parts completely. What tools and materials are ideally needed, and are there common mistakes I should avoid?
Thank you in advance for your tips and advice!
teo33
21 Aug 2017 09:03
most of the time, squeaking is caused by loose screws. Simply tighten all screws and connections. After that, you can apply some silicone spray or an appropriate furniture wax or graphite paste to the areas where wood rubs against wood.
Merlin52
21 Aug 2017 10:29
Hello Xenoge,
I’m happy to provide a detailed guide on how to fix squeaky Malm furniture, as the exact procedure and choice of materials are crucial:
1. Analysis: Gently apply pressure to the furniture and precisely identify the squeaky spots. These are usually joints or screw connections where wood rubs against wood or wood against metal.
2. Check screws: Inspect all screws for tightness. Always tighten any loose screws first, as this is sometimes enough to solve the problem.
3. Cleaning: Remove dust and dirt, especially from the connection points. A brush or compressed air works well for this.
4. Lubrication: For wooden joints, wax (e.g., beeswax) or graphite powder is best, because oil or grease attracts dust and can make the problem worse.
5. Metal connections: Silicone spray is often a good choice here, as it doesn’t gum up and reduces the squeaking noise.
6. Test: After lubrication, move or load the furniture several times to distribute the product thoroughly.
Common mistakes:
- Using oil or WD-40 on wood: this attracts dirt and can stain the surface.
- Over-tightening screws: this weakens the material and can cause more play.
Tools: Allen key (matching the furniture fasteners), brush, fine lubricant (wax or graphite), and possibly silicone spray.
Regards!
Connor
21 Aug 2017 15:07
Merlin52 schrieb:
Most of the time, it’s joints or screw connections where wood rubs against wood or wood against metal.
Why such a fuss about this kind of furniture? Malm is almost notorious for its noises. In my opinion, it’s just poorly manufactured particleboard that squeaks and creaks.
I’m not surprised these pieces need constant maintenance. Those who value quality prefer investing in solid wood and avoid the problem altogether. Just a thought.
Peone
22 Aug 2017 07:52
I understand the frustration regarding the quality, but Malm furniture is popular with many due to its appearance and price.
@Xenoge, if you are still unsure, here is a clear explanation of the steps you can take:
1. Preparation: Gather all the necessary tools. These usually include the appropriate Allen wrench (often included with IKEA furniture), a screwdriver, and a soft cloth.
2. Disassembling the furniture? Usually not necessary, but if there is persistent squeaking, you can slightly loosen and retighten individual joints. Lightly roughen the connecting wood with fine sandpaper – this reduces friction.
3. Lubrication: Avoid using grease or oil. It’s better to use beeswax or graphite. A thin layer of wax reduces friction noise without damaging the surface.
4. Check the furniture feet – sometimes incompatible foot pads are the cause of the noise.
5. Finally, tighten all screws evenly. Check again after a few days!
If you have any more questions, feel free to ask 🙂
teo33
22 Aug 2017 09:18
Connor schrieb:
In my opinion, this is cheap manufactured particleboard
The debate about materials is honestly a bit off-topic here. Whether solid wood or particleboard – any piece of furniture can creak if joints come loose or rub against each other.
It’s better to focus on repair solutions.
