ᐅ How can I fix squeaky Billy cabinet doors myself?
Created on: 18 Jan 2019 08:13
MARABI
Hello everyone, I have been having an issue for some time now with the doors of my IKEA Billy bookshelf squeaking when I open or close them. These are the standard wooden doors with fixed hinges. The squeaking is quite loud and becomes annoying over time. I would like to fix the doors myself without having to replace entire parts or call a professional.
Can someone please explain the best steps to effectively eliminate the squeaking? What products or tools do I need, and what should I pay attention to so that the doors operate smoothly again?
I have considered that the problem might be with the hinges or possibly the installation, but since I did not assemble the Billy bookshelf myself, I am uncertain. Thanks in advance for your help!
Mariah
18 Jan 2019 13:33
A small tip from experience: When you take the doors off their hinges, it’s best to lay them on a soft surface to prevent scratches when setting them down. This is especially helpful if your doors are painted.
Also, after lubricating, wipe the hinges again with a cloth if too much lubricant drips off. This helps prevent unsightly stains on the wooden parts.
noge58
19 Jan 2019 08:18
I’m checking in again! Over the weekend, I treated my Billy doors with silicone spray and also removed the hinges as described. Result: No more squeaking at all! I’m really happy and can encourage everyone to try it themselves. It’s really not complicated! 🙂
mifra
19 Jan 2019 09:42
As an additional note: With frequent use, it can be helpful to repeat lubrication approximately every 6-12 months to prevent the return of squeaking. Regularly checking that screws are tightly secured also extends the life of the hinges and prevents loose fittings that can cause noise.
Luchen
19 Jan 2019 10:07
If you don’t like sprays, you can also use liquid graphite. It leaves no residue on the wood.
teo33
19 Jan 2019 10:33
For those who prefer not to use sprays or oils: Sometimes applying a small amount of silicone grease with a fine brush can help. It takes a bit longer but is less volatile.
MARABI
19 Jan 2019 12:29
Thank you very much for all the valuable suggestions! I will address this soon. I found the advice on safe dismounting and lubricants especially helpful. I will provide feedback once I have tried it myself 🙂
