ᐅ How do I repair small scratches on IKEA Brimnes furniture?
Created on: 18 Oct 2022 08:23
ParkingstoP
Parkingsto18 Oct 2022 08:23Hello everyone, some time ago I bought a few IKEA Brimnes furniture pieces, and unfortunately, small scratches have appeared on some edges and surfaces. I am now looking for a simple and effective way to repair or conceal these minor scratches without causing noticeable differences or damaging the surface. I am especially interested in which products or techniques work best for the typical materials used in Brimnes furniture – such as laminate or foil coverings. Perhaps there are special repair kits or home remedies you could recommend? It would also be helpful to know if the surface needs any preparation before repair (e.g., cleaning, sanding) or if you can start right away. Thanks in advance for your tips!
Hello Parkingsto, I understand your concern well, as such small damages often affect the overall appearance significantly. As you already mentioned, the first important step is to clean the surface – preferably with a mild cleaning agent and a soft cloth to avoid leaving any residue. You should avoid sanding with laminate or veneer, as this can damage the protective layer. Instead, special furniture repair kits are helpful, which usually consist of colored waxes or markers. You can carefully work these into the scratch and then wipe off any excess. Sometimes it is recommended to choose a color that is slightly darker than the furniture surface, as light areas tend to be less noticeable when repaired this way. Very small scratches usually disappear quite well with these products, while larger damages typically require professional refinishing or replacement parts from IKEA. In any case, work patiently, applying several thin layers rather than one thick one. If you like, I can also recommend some typical products that I have already tried.
Naomige schrieb:
Sometimes it’s recommended to choose a color tone slightly darker than the furniture surface, as lighter spots are less noticeable when repaired this way. I see it differently. Especially with laminate or foil surfaces, the finish is defined not only by color but also by gloss. In my opinion, simply covering scratches with a color does not really conceal them – the difference is usually still visible, particularly in bright light. You need a solution that also takes the texture into account, and waxes or touch-up pens are often just half-hearted attempts. If you want to do it properly, you have to carefully sand the affected area and then apply a suitable sealant or lacquer layer. Of course, this is labor-intensive, but the repair then really looks like the original. Most DIY repairs remain visible. Of course, this is not everyone’s preference, but if you value a perfect finish, you shouldn’t settle for half-hearted methods.
GALEO4 schrieb:
If you want to do it properly, you need to carefully sand the affected area and then apply a suitable sealant or coat of paint. That is basically correct, but you should be very cautious when sanding Brimnes furniture, as the top layer is often a thin foil or laminate that does not respond well to refinishing. Excessive sanding can cause permanent damage to the surface. Therefore, I recommend a gentler approach first: clean the surface, then fill the scratch with a special repair wax or furniture marker. It is important to polish the product smoothly with a soft cloth after a short drying time to blend the surface. If the damage is larger, you can try sealing the area with a clear furniture or lacquer pen. In practice, however, every type of laminate or foil reacts differently, so testing on hidden spots is advisable. Finally, it is important to continue caring for the furniture to make the repair last as long as possible.
