I recently installed an Ikea Metod countertop in my kitchen. Unfortunately, I have already noticed some minor scratches that are quite noticeable. The countertop has a melamine coating with a smooth, matte surface. Now I’m considering how to best repair these small scratches without sanding down the entire surface or replacing the countertop completely.
My question is: What are the options for repairing small scratches in Ikea Metod countertops yourself? Which products or methods are proven and carry the least risk of further damaging the surface?
I have already thought about using special wood repair kits but I’m unsure if they are suitable for melamine finishes. Tips on surface preparation and application would also be helpful.
Thank you in advance!
A few tips about sanding: Be sure to use fine sandpaper with a grit of at least 1000, preferably 1500.
- Apply very light pressure and always move the paper in the direction of the panel, not back and forth.
- Sand only lightly, mainly to smooth the roughness of the scratches.
- After sanding, clean the area thoroughly with a lint-free cloth.
The pens should be specifically designed for melamine or laminate surfaces and match the color as closely as possible. Brands like "Beckmann" or "Marabu" offer such repair pens, which are available at most home improvement stores. Be sure to read the instructions carefully before purchase.
For use: Apply the pen sparingly to the scratches, allow it to dry, and then gently polish with a soft cloth.
tifigu schrieb:
Can you recommend a specific manufacturer or are there particular qualities I should look for in the repair pen?
Hey tifigu,
I once rescued an Ikea Metod panel with a small scratch using a simple trick that I usually apply for minor blemishes:
- First: Apply a small amount of petroleum jelly (yes, it sounds strange, but it works great) sparingly on the scratches.
- Gently rub it in with a soft cloth; this visually conceals the scratches and makes the surface a bit smoother.
Of course, this doesn’t replace a proper repair, but if you need a quick fix and the scratches aren’t too deep, it looks much better afterward.
If you want a more durable solution, you can combine this with a fine repair wax and then apply petroleum jelly again for final touch-up.
Good luck! And don’t worry—these panels are tougher than you might think.
